After inserting fob no dash lights, no start, after 5-10 times cranks and works normaly. Often both ofthe key fobs are not detected (no warning on the cluster , but nothing happens) in socket. sometimes starts with dashlights normally. I was told that it may be ignition module failure. What may have failed and How to fix it.
SOURCE: 1997 C200 Key Fob Failure
Max, how did you fix your problem? The same thing happened to me today and I have to call the dealership I assume. Thanks, Judy
SOURCE: Merc CLK 320 (2003) - key fobs worked this
Sorry but my alldata book is stating they can only be re programmed with dealer diagnostic equipment
SOURCE: Starter motor not turning over when key is turned
Have a mechanic look but it sounds like the bendix which spins the starter is bad, usually if bad exactly what you are describing. When you try to start it engages and in a lot of cases if just a click and then will work at other times it is the problem---If the starter has been there for a while replace it and the bendix which almost always come as a unit.
