I "source" to AUX, push the volume button up and the sound bar works fine for about a minute then turns itself off and displays D IN. How do I make the sound bar work continuously?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears. 2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method. Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar. 2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar. 2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar. 2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 2
Method 3
Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
Press the MENU button.
Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
hold down the function button until the display changes. you can then toggle things like dimmer ,aux, and demo by turning volume control. when you see demo push the play/pause button which will then allow you to turn it off by again turning the volume button. once its off press play/pause button which will allow you to toggle other functions. then hold function key down again to get back to main display(main display will eventually return on its own)
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
To set the time and/or cancel the demo mode, you need to enter "PSM" mode. Do this by pressing and holding the "sel" button for 4 seconds. Use the left/right rocker switch to select the item. Turn the "volume" knob up/down to change the item. Press "sel" again the exit PSM mode.
So to turn demo mode off: 1) Press and hold "sel". 2) Press right until "demo" is displayed. 3) Turn volume knob until "demo off" is displayed. 4) press "sel" again to exit PSM.
To set the time: 1) Press and hold "sel". 2) Press right until "CLOCK H" is displayed. 3) Turn volume knob until correct hour is set. 4) Press right until "CLOCK M" is displayed. 5) Turn volume knob until correct minutes are set. 6) Press "sel" to exit PSM.
Hope this helps. If it does, please rate as "FixYa".
This is easy, Press in and hold the function button and the volume dial,.. after the function menu comes up press function again to get to Aux off.. press up to get it to Aux 1 and then press in the volume dial again and youre set!
Hold down the "SEL" button, and use the CD track skip button to scroll to where the display says "DEMO," and use the volume knob to change the setting to "OFF." Push SEL again and you're good to go.
To turn off the demo you need to press the src button to put it in standby mode. Then press the menu button as if to change the settings and use the joystick to scroll right until you see demo, then turn it to off....
Do as above to allow you to enter AUX mode this will let you plug in your MP3 player to the input on the face and hear music through it ;)
Here is how to shut off the demo:
1) Press and hold the SEL button for several second until DEMO appears on the display. Release your finger from the SEL button.
2) Using the Volume control knob, turn left or right to turn on/off DEMO.
3) Press and release the SEL button to accept.
Setting the clock:
1) Press and hold the SEL button for several seconds until the DEMO shows on the display.
2) Use the right search arrow in the 4-way button just above the SEL to get to the clock hour. Do not use the up or down key.
3) Turn the volume control knob to select the hour.
4) press the right arrow once more to get to the clock minute.
5) Turn the volume control knob to select the minute.
6) When finish, press and release the SEL to accept.
I don't know if you have figured out how to turn the AUX port on yet, but I just figured it out. First, turn the CD Player off by quickly pushing the "Source" button. This is also the volume knob. Then, after the player is off, hold down the "Source" button. This will bring up the initial setup. Use the arrow keys to navigate through the options. One of the options is to turn the AUX port on. Once this is finished, turn the unit back on and you're ready to go.
