Separate TV buttons are not on an input, so it does not tell you how to set the TV codes, although the manual lists a gazillion different TV codes.
Do any experts know the answer to this question? It has been posted multiple times, but I dont' see any answers! It is a pitiful manual that is provided by Yamaha for this purpose and nothing is intuitive about making this work. If anyone know the answer, PLEASE POST IT!
Here's how I got mine to work. I found the answer from another user. Thanks, Buddy! I don't know how you ever figured this out since it is defintely not in the manual. Furthermore, the Yamaha website is so out-of-date, the manual downloads don't even exist. Great job!
1) Press the "code set" button with a pen or straightened paper clip
2) Press the [A] key (next to "V-AUX")
3) Enter the code
Test it by pressing the Power key in the TV section on the remote (NOT the "Source" Power" key or Main power key at the top).
Depending on the remote the TV will be pre-linked to one of the inputs. In the case of the RAV290 it seems to be AV1. So setup your TV for AV1 and it should work.
Solution: Yamaha remote RAV 290
1) Press Code set: then it blinks twice..
2) Press HDMI button either 1,2,3 or 4 on which you want to re-assign the remote code. (then it blinks one time)
3) Press the code of the TV, DVD or any equipment listed its a four digit. example for Hitachi TV 1s 0014.
this will be the pattern...
press code set button, (blink twice)
press HDMI button sample 1
then input the code of hitachi which is 0014
then blink twice.. succesfull..
I found this at: http://faq.yamaha.com/us/en/article/audio-visual/av-receivers-amps/rx/rx-v667/4722/4063/ Last Update: 11/20/2010
Using the RX-V667 remote to control your TV
RX-V667: How to program remote control codes for TV Control Key Operations
Note: The following steps must be
completed within 1 minute. Settings will be automatically stopped after
1 minute passes since the last operation and steps 2 through 4 will
have to be repeated.
How do i set a cd player code or is that posisble with this remote thanks.
I lost the one for my cd player
