It may be possible. First, create a new project on Printmaster 2019 and save it. There's no need to actually print it, just save it. Go to the folder where you saved the new project and look at the file type. Is it a SIG file? If so, you may import (or copy and paste) your older saved projects into the same folder as the new saved project. Then the older projects can be opened in Printmaster 2019.
If the new project file type is not SIG then note what type it is. Next, make a copy of the older saved projects folder. Open the copied folder. Left-click to highlight a project, then right-click on it and select "Rename". Keep the same project name, but change the file type from SIG to the new file type used in Printmaster 2019. Next, try opening that renamed project with Printmaster 2019. If the old renamed project is compatible with Printmaster 2019 it will open, ready to use. If it does not open ready to use then your only hope is to contact Printmaster tech support (probably by email) and ask if there's a fix to make older projects compatible.
See if you can repair the program by just reinstalling it again . Or you can save your projects in a temporary folder and then uninstall and reinstall the program. Afterwards you put your projects back.
You need to convert the PSM image to a standard clipart format such GIF or JPEG. You can use a screen capture program such as Hypersnap from http://www.hyperionics.com.
You can clip the picture and use it in other applications.
Let me know if this will work for you. Thanks.
You'll find that you have to select (highlight) copy and then paste it to say, a word file. Now about the only way you can accurately print something from the internet is if you see Printer Friendly- or print from copy. If you have never copied and pasted before this is very useful...Select what you want to copy, right click and you see the word copy...now as long as you don't right click again it will stay just as you selected it. Now go to Word, word pad, note pad, almost and thing with a blinking cursor, open it and right click again and choose Paste this time and what ever you copied will be displayed. Very useful commands, Good choice on printers, I have a photosmart 1000 and it still works like new. Hope you can follow my jibberish. Please leave a rating, thank you kindly
It is the print setting in WP. As I'm sure you know, Corel products like to take control of everything. If your document is configure to print to an HP printer, for example, it won't print to another printer unless you change it in the Print settings within the document.
Seems like you need to replace its convergence amplifier ICs (2 pcs). The convergence amplifiers are attached vertically to two heatsinks. When replacing these, remember to reapply thermal paste (white paste for better heat transfer from IC to heatsink). If you don't replace these, over time other components will be affected.
