There was a flash from within the unit and now the lights will no longer work. I hear the clicking of the switch, going through low, high, and off. I can't find a fuse anywhere, but I did not disassemble. I removed the key pad and there is no visible sign of burn. I bypassed, or thought I did, the lines to the lights inorder to add a manual switch. That did not work. I thought it may be the control board ($90 approx.), but LG won't sell me that part and there are 2 authorized service shops in town and they don't want to sell me the part. The control board may not be the problem. I would rather buy a new microwave for $600 than have this one repaired at what could be close to $300. Any help or hints would be greatly appreciated. Thank you. Matt
In this case as the display does not show a clock then it seems the program controller is not working correctly. So check power - step down supply, if the pads are responding- if not faulty pads. Also the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Now unless the display works and the processor starts to switch on the MAGNETRON , the table and light will also switch on as it must heat.
So it is necessary to check the main controller unit as it seems to be the suspect..
