Manuals for American standard whirlpool tub parts
SOURCE: how do you remove the jets on an american standard whirlpool tub
The jets have a nut on the back of the jet. I hope you have access or else you will need to pull the tub for this job. Loosen the nut and squeeze aquarium grade silicone in between the tub wall and the nut, Tighten the nut, but not to tight. Let set over night fill and check for leaks the next day.
SOURCE: My American Standard whirlpool pump will only hum.
The bearings (or bushings) of the pump or pump motor have siezed, these can be replaced on some models but for the most part you will need to replace the pump and/or pump motor. and as where to get parts, i would suggest the outlet from wich you purchased the unit or another appliance outlet. Or if you feel up to the challenge, im sure you could find replacement parts on the internet: google, ebay, etc.
SOURCE: i have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
SOURCE: I have an American Standard
You need to get in the yellow pages and look in the Bathtub section for repairman
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Replacement Air Switch will cost you about $20
US Parts Center
