HP Photosmart 3210 Printer Logo
A
Anonymous Posted on Aug 22, 2015
Can I send and receive faxes?
How do you send and receive faxes on this machine. I amusing DELL desk top running Windows XP SP3.
electronic & computer repair& servicre
Level 3:
  • HP Master 12,061 Answers
  • Posted on Aug 22, 2015
HP Master
Level 3:
Answers
12061
Questions
0
Helped
4007578
Points
36390
U need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Install xp
a aziz,
Click the link below for instructions for manually reinstalling windows xp. You will also need to download xp sp3 from the Microsoft Website below.
XP SP3 Download
http://dell.to/1bjsYPI
Reinstall Windows XP
http://dell.to/18Vo1MN
Thank You,
Dell-Jesse L
Dell Social Media and Communities
tip
How to Configure Windows XP to send and receive Fax?
If you are using windows XP, you can use sending and receiving option for fax service built into windows XP. You can enjoy free facilities of fax from your computer, because buying a dedicated fax machine for home or small office may not be a feasible option. Using windows XP based fax services; you can read, save, forward, delete the fax messages. By default fax service is not installed in your windows XP, but if you have windows XP CD, you can install fax feature using Add or Remove Program option.
Follow the gives steps to install fax components:
  • To install this feature, you will need to be logged into your computer with administrative rights.
  • Make sure, you have installed modem driver on your computer before running fax components setup.
  • Now click on Start button and go to System Control Panel then double click on Add or Remove Program.
  • Select the Fax services check box under Add or Remove Windows components.
  • Now click Next to finish the fax installation wizard and close it.
After the fax components installed, now configure the fax setting before using it.
  • First click on Start button, go to All Programs> Accessories> Communications then click on Fax Console.
  • Now in fax configuration wizard, type the fax cover page information then click on Next.
  • Select the suitable modem for fax and also enable others send and receive options.
  • Now type the TSID (Transmitting Subscriber Identification) and click Next then type here CSID (Called Subscriber Identification) and again Next.
  • At the end select the printer to be automatically printing the fax and click to finish.
on Feb 13, 2010 • Computers & Internet
1helpful
No xp cd how can i reintall xp on dell inspiron 6000 using the product key on it
You can download a copy of a dell windows disc from a torrent site, and use your key.
I found 1 for you, you will need a torrent client, i use Utorrent, you can also use limewire.
It says this on the file...
This is a dell xp home iso slipstreamed with sp3. It can be used to install windows on dell machines with the oem sticker and activate without problems. You can also use it to run repair installs on them without loosing all updates prior to sp3.
Just OPEN the file with your torrent program and let it download, it will be in an ISO file, Just burn it to a disc as an image, Use IMGBURN, its free
http://isohunt.com/torrent_details/42684159/dell+xp+home?tab=summary
1helpful
Big Mutha Truckers won't run with windows 7 home premium
SORRY BUT YOU CANT TURN IT IN VISTA
TRY TO GET XP SP3 ITS MUCH BETTER AND RELIEBLE AND YOU CAN TURN ALL OF YOUR GAMES WITHOUT PROBLEMS
Dell dimension 3000 series won,t install drivers and utilities cd after fresh install of windows xp sp2
Hello
Run the windows update again to win sp3.
Sp3 has most of the drivers in the dowload.IF not you should be able to install utilities after you get win xp sp3
1helpful
Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
1helpful
Cannot access anything on computer!!
Maybe the explorer is not loading automatically. As you start Task Manager from Ctrl+Alt+Del, go to new task and run explorer.exe.
OR If it still doesn't solve the problem try and repair the XP installation if you have the XP CD
2answers
Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Can't get the Fax Machine to SEND a fax
Check to make sure that "mode" is correct. "Auto Receive", and/or, "fax" mode (not printer, etc.,)
Anne
k24674
Grand Canyon Tech
Grand Canyon Tech
