Maytag MAH2400A Front Load Washer Logo
Pamela Bennett Posted on Aug 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I fix this?
Leaking water from door and flashing LF code
Richard C Cohen
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Maytag Expert 318 Answers
  • Posted on Aug 21, 2015
Richard C Cohen
Maytag Expert
Level 2:
Legend:
Answers
318
Questions
0
Helped
120799
Points
917
Hello. There is an LE error that means "fill error". There is also a "tE" error that means "sump thermistor failure". You are probably getting the tE error--the thermistor is located at the bottom front of the washer tub in the center. If water is leaking from the bellow(the rubber part that seals tightly against the door), it might be spilling down onto the thermistor wires, shorting it out. With any leak, this will be an INVOLVED repair. My suggestion is to call for service--to reach anything in the front of the washer internally, the front panel must be removed--this is complex, and must be done carefully, especially if the bellow is leaking and needs to be replaced. I hope I helped you!
Whirlpool LF Error code
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
1helpful
F error code "kenmore top load" washer oasis he3
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
2helpful
What does the code LF stand for? It keeps stopping half way through the wash cycle and flashes this code.
LF is for long fill.
Check the following:
? Is water supply connected and turned on?
? Are hose screens plugged?
? Is water entering the tub?
If all these are good and water is going in fast (both hot and cold) you may need a service company to come out and take a look
5helpful
Code lf keeps popping up
lf code means long fill. If the water fill time exceeds 10 minutes, the water valves are turned off and lf is flashed. Press STOP/CANCEL to clear the display.
5helpful
What does the code Lf mean?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
2helpful
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
1helpful
Calypso Washer is not washing clothes or spinning; getting LF error message. Water is going into the machine but no washing action.
Hi There
I'm Sending you the fault codes. Hope this helps you and get you in the right direction.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
6helpful
The washer is showing a code of LF what does this mean
LF Long Fill
12helpful
2answers
Maytag Bravos top load gives LF code not working. Any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
5helpful
3answers
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
