There are a couple of different heads that doesn't have a spool on 1 you pull the left over pieces of old string out from under the and the push the new short pieces into the front of the head, another you line up two arrows and then put a long piece of string throw the head eqail on both sides and then wind the head to pull the string in, another you take off and feed the line down inside.
The head will have to be pulled off by taking the nut off of the bottom and then take the spool off and resting the spool. If the string is new it may be the wrong size string.
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM
Head)
Use 2.4mm monofilament string. Use original
manufacturer's replacement string for best performance.
n Stop the engine and disconnect the spark plug wire.
n Cut one piece of string approximately 7.6m in length.
n Rotate knob on string head until line on knob aligns
with arrows on top of string head.
n Insert one end of string into eyelet located on the
side of the string head and push until string comes
out through eyelet on the other side. Continue to
push string through the string head until the middle
section of the string is inside the string head and
string outside the string head is evenly divided on
each side.
n Rotate the knob counterclockwise on the string head
to wind the string. Wind the string until approximately
20cm remains protruding from the string head.
INSTALLING STRING IN PRO CUT II STRING
HEAD
Use monofilament string between 2.4 mm and 2.7 mm
diameter. Use original manufacturer's replacement string
n Gather two of the pre-cut lengths of trimmer line provided
or cut two pieces of trimmer line, in 28 cm lengths.
n Insert the strings into the slots located on the sides of
the string head. String should be pushed in until
approximately 2 cm protrudes from the holes on the
top of the string head.
n Remove old string by pulling it from the holes located
on the top of the string head.
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
This trimmer is an "AFS" (Automatic Feed System) trimmer meaning the trimmer uses centrifugal force and a lever that play out trimmer line without you ahving to bump it on the ground. Your trimmer uses .080" diamter line. You can get a replacement spool and lever at Lowe's fairly cheap. I would say get the spool that is already wound rather than trying to buy just the line and re-spooling...that will make this a LOT easier!
What you do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head of the trimmer and follow the steps below:
1. Remove the spool cover (this is the orange cap on the head)
2. Remove the spool, (observe and note the orientation of the spool!)
3. Using a pair of pliers, pull the orange feed lever straight out (observe and note the orientation of the lever!)...do not try to pry it off, you will damage the head!
4. Insert the new lever in the same orientation you noted when you removed the old one.
5. Insert the new spool and line in the same orientation as the old spool.
6. Replace the cap.
Black and Decker has an 800 number you can call if you get stuck, the number is 1-800-544-6986. Good Luck!
cut to pieces of string about 8 ft long. run your line through the holes on the side of the head. you will see 2 smaller holes on the inside. put the string in those 2 holes and begin turning your head to install the string.
After you line up the two triangles, push in and lift. Only the top piece will come off, then the spool is inside. I kept trying to lift the whole head and then the top popped off and I realized what I was doing wrong. It is actually quite easy once you figure out the correct way and where to pull.
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
