All hoses were broken and turned into plastic dust.could you diagram the fuel lines for me please thanks.
Hi Kenneth,
Here is a video on how to solve your problem:
https://www.youtube.com/watch?v=bVw9G5XVLxE
Good Luck!
Jim
SOURCE: replace fuel lines,craftsman weedwacker,
Fuel filter in tank with line going directly to the fuel pump side of the carburetor This is the end of the carb with a solid cover. . This line should have length in it inside the tank where it can flop around and stay on the bottom to collect fuel. The other line in the tank should have one of the little connectors on it and can be right up to where the hole in the tank is to hold it there.. This line should connect to purge/primer bulb on the longer outlet nipple. Another fuel line should run from the metering chamber side of the carb (the end with the hole in the cover) to the purge/primer bulb with the shorter outlet nipple.
The purge bulb "pulls" fresh fuel out of the tank via a vacuum created after depressing the bulb and the fresh fuel flows completely thru the carb and any air or old fuel ahead of it are drawn to the purge bulb which then "pushes" this mixture back to the fuel tank.
SOURCE: My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Testimonial: "Thank you. I had to merely add more gas to tank & bulb siphoned fine. Changed the plug and bingo! It started & runs great. "
