Question about Powerware Computers & Internet
In my powerware 9120 6kva g4pc50w mosfet brust. what is its main cause and solution ?
With psdr pic and and show the place where where to check
    Top Expert:
  • Powerware Master
  • 63,052 Answers
Sorry but reading this question tells me nothing MOSFET BRUST
Posted on Aug 20, 2015
SOURCE:
Powerware5115 will not switch on
A weak or dead battery pack its the main reason of a unresponsive/good health UPS, but never forget to test the electric cord, the fuse and the protective relay.first, this sounds too simple, but thats a common fault.
Battery pack must have at least 5 volts with half amp of current to power up the UPS internal relays, giving electric power to the main switch.
To rise the 12/24 DC volts to 115/120 AC volts, the UPS uses some electronic components (semiconductors) called MOSFETS , and sometimes, blown (browned) MOSFETS on the electric board are the most desastrous cause of a unresponsive (completely dead) or faulty UPS. (I remember that some time ago I see a TRIPP LITE SMART 1500LCD UPS with twelve blown MOSFETS, when happened, that kind of fault must be saw like a little volcano!).
If you know how to take all the safety electric measures, and how to use a portable voltmeter, you can test the voltage/amperage on the battery pack, the electric cord and the replaceable fuse (if has any). Basic and intermediate electronic knowledge is necessary to test MOSFETS and other electronic components on the circuit board.
Aug 09, 2014 | Powerware 9120 UPS System
We re having problem with the 9120 powerwere UPS...no backup when the utility (commercial power ) is not available...the UPS shut down, and all LEDs went off.
open the ups and check whether the battery faulty or not if faulty replace it, if ok then check mosfet or IGBT used in inverter section if faulty replace it problem wil be solved
Mar 09, 2010 | Eaton Powerware® 9120 UPS System
Battery disconneted problem
there is a fuse blown inside the ups open the ups and replace the fuse in series with battery if it blows again the check igbt or mosfet
Feb 19, 2010 | Powerware 9120 UPS System
My UPS Powerware 9120 6kva. At inverter section. what is the component type for Q213,Q214,Q215 and Q216, i means type and it part number. Can U forward to me the Service Manual for that UPS. TQ
no but I can tell you that for old ups mosfets are used and for new ups IGBT (insulated gate bipolar transistor )are used the IGBTs are not available on shops you have to take help of company
Feb 18, 2010 | Powerware 9120 UPS System
Rectifier and heatsink temperature sensor not ok for 9390 powerware ups system. When i switch on the 9390 ups a message appears which reads check rect temperature sensor and check heatsink temperature...
it could be your uPS given the problem the mosfet might be spoil... as the temperture is high because of the transformer is not given the clean current to bypass the systems and the there not much air filter out from the ups depend on the condition of the room might be too warm.. there a higher chance was the mainboard problem well u check the sensor lst and also try to unplug and plug bk to restart the sensor... if it will not slove the problem check with the vendor to come down and check..
May 18, 2009 | Powerware 9120 UPS System
Powerware 9330
your problem could be related to a dispay board or possible CSB board.
Sep 24, 2008 | Powerware Invensys 9330 Model 40 UPS...
Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
Feb 20, 2008 | Powerware 9120 UPS System
9120 Battery Failure
sounds like inverter is unhappy(causing the input fuse to blow. maybe, just maybe, this Powerware 9120 has given up the ghost? The inverter can short for a variety of reasons. Try to take out the battery completely, and run it as just a power conditioner. If that works, then you have an unhappy inverter in there.
Feb 05, 2008 | Powerware 9120 UPS System
Powerware 9120 DC Bus Fault Problem.
there is a 100uf/63v capacitor near the IRF630 fet. You need to replace this in order to fix this error. Along there is also a 2200uf/16v capacitor. It is a good idea to change the both at the same time.
Feb 13, 2007 | Powerware 9120 UPS System
Computers & Internet Logo
411 people viewed this question
Top Powerware Computers & Internet Experts
Marvin
Marvin
geekyshrink
geekyshrink
Level 1 Expert
B.Th. Pluijm
B.Th. Pluijm
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
