I have IRT4520 for many years. But, now, when I turn on, it flashes with 188.8 except the lower half of the first 8 has a forward slash, and the 3rd 8 has a vertical line down in the middle. Instead of F/C , it shows an E. on the screen. It also shows the horn-like image, followed by mem, and E.
It doesn't do any reading at this point.
I have replaced the batteries, but it still has the same problem.
is the drawer that its stored in, in the bathroom? the humidity or moisture could affect it. I have had mine for 8 yrs and works perfectly. Are you placing the probe covers on correctly and waiting for it to click or a pop before inserting into ur ear.?
Sounds like your main digital board is fat fault. ther isn't much you can do except replace the board or find a service tech to repair the faulty part.
Press and hold the RESET button on the bottom of the nüvi for several seconds. Clearing User Data CAUTION: This deletes all user-entered information. 1. Hold your finger on the lower-right corner of the nüvi screen while turning on the nüvi. 2. Keep your finger pressed until the pop-up window appears. 3. Touch Yes to clear all user data.
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
>Paraphrasing from the manual: >1. Turn off headset. >2. Press & hold
the Multi-function button for 8 seconds, until >the lower half is lit up
blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter. >3. Set your 'phone to discover bluetooth devices. >4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you
want to pair with it. Confirm by pressing "Yes" or >"OK". >5. Enter
passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
i think its is a problem that most of the jazz elite are having.i had mine for only two days then it went dead.i brought to repairs and they told me to throw it away.i put it back in the box and put it away. about 4 weeks after i decide to take it up and plug it in. to my surprise it starts to work and it works perfectly well. just give a little time.i know how u feel
As Quoted from Arfur - see bold print if you are having problems. You
don't need to unpair the other phone, it will unpair itself.:
As Quoted from Arfur - see bold print if you are having problems. You don't need to unpair the other phone, it will unpair itself.:
