It has a malfunction
Sir/Mam, turn off the main power switch(INSIDE), ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it see a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Testimonial: "This is exactly what I needed to do to fix this error. I got it fixed a long time ago but this is the correct answer!!!"
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
