Have you oiled your Bernina recently/regularly? Consult your owner's manual under the Maintenance section. Sounds like the old oil may have dried and is prohibiting the needle bar from moving. Use good quality (ie Bernina) oil, not 3-in-1, WD-40, cooking oil, or the sewing machine oil from your grandmother's sewing basket). To help free it up, direct heated air from a handheld hairdryer into the interior mechanism of the machine, concentrating on the needle bar area.
I keep it cleaned and. oiled..i sew alot..i broke the stich plate..haha..how bad did i mess it up
SOURCE: Pfaff 362 won't zig zag
yes, it's very possible that the control/knob needs to be replaced
or the cam or gear that works the zigzag
SOURCE: needle position
Hmmm sounds like an issue I had/have with a singer stylist. There is a knuckle part that connects the zig zag mechanism to the needle bar. Mine had a pin that kept slipping out. When I took it apart (and lost the pin) I also discovered that the "round" holes the pin went into were work out and were more like ovals. The machine is now a parts machine.
