SOURCE: voice mail greeting
Sign in to mailbox 999 and 998 and poke around. You should find some greetings in there. Else, if you have the installer software you can go in from that and make the changes.
SOURCE: Panasonic KX-T7331
If it's a Panasonic brand VM, you log in as administrator to mailbox 999. Option 6 1 3 allows you to reset a mailbox password.
Carl
SOURCE: Changing the voice mail access number.
press menu
arrow down to "Initial setting"
press select
"voice mail" will sow on the screen
press select
"store VM access#" will sow on the screen
press select
edit the number and press save
SOURCE: New Voice Mail message
You received a message on the voicemail system provided by your telephone company. To hear the message, dial the voicemail number provided by your service provider (in many cases, this will be your own phone number), and follow the voice instructions for listening to your messages. You need to store the voicemail access # by pressing [MENU], [#] [3],[3],[1] on the handset. To access the voicemail, press [TALK], then softkey [VM]. Depending on your service provider, you may need to clear your voice mailbox to remove the notification.
SOURCE: how do I change name
From the phone connected to Jack 01 or the authorized phone (generally 101) press PROG and dial **1234 Dial 004 and ENTER and dial the ext number of the phone you want to change Use the keypad to enter the name (you have Upper and Lowercase letters) and the arrow key to step to the next character. When you finish, press STORE.
Carl
