Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
Temp.Control Panel indicator is Red, what can i do?
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Jan 08, 2008
SOURCE: Active Smart Temperature Control Panel - Red Light
it is possible that it is the cooling regulator that is having a fault. The F&P customer service centre will / should be able to help diagnose this over the phone and give you a much better idea what u should do.
Fridge keeps bleeping
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls Ā·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open Ā·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
Ā·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset Ā·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Panel beeping and nonresponsive
Refridgerator beeps
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
How do you get the model 370lb to stopping beeping
3answers
Open door 18 beeps lights flash red green fridge not cooling
Keeps beeping without stopping
MY FRIGIDAIRE FRIDGE IS BEEPING AND NOT STAYING COOL
1helpful
The cooling fans are only starting when the termometer is indicating 3/4 in the red zone. They work for one or two minutes and stop when the indicator in in 1/4 on the red zone.
sounds like u have a temp cooling censer problem,,turn ur heater control to defrost or a/c,,one fan should come on & stay on till u switch it off,,the other fan run off a temp sender,,,,hoped it helped
2helpful
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
need to know so i can help you
Top Fisher and Paykel Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
