Yamaha RX-V661 Receiver Logo
A
Anonymous Posted on Aug 18, 2015
Relay tripped shutdown - Yamaha RX-V661 Receiver
Steven Wander
Level 3:
  • Master 599 Answers
  • Posted on Aug 18, 2015
Steven Wander
Master
Level 3:
Answers
599
Questions
Helped
286542
Points
1337
Most of the time a shutdown is a protection circuit caused by a shorted speaker. Unplug speakers and see if it will turn back on, then hook up one at a time and power up to find if one has a short.
1helpful
2answers
Wont start2004 dodge grand caravan sxt code p0685 show on dash
P0685 DODGE - Auto Shutdown Relay Control Circuit Failure
Possible causes - Faulty Engine Control Module (ECM) power relay
- ECM power relay harness is open or shorted
- ECM power relay circuit poor electrical connection
- Faulty (ECM
Possible symptoms:
Engine Light ON (or Service Engine Soon Warning Light) P0685 Dodge Description: Short or open in Auto Shutdown (ASD) relay circuit, this relay is under the hood in the relay center.
Location of reset fuel switch for 2002 Jeep Liberty Sport
Jeep doesn't use a fuel pump reset AKA "Inertia activated fuel pump cut off switch" You have what is called the ASD relay under the hood that will trip the pump power in a crash. Follow the link for more info on the ASD Symptoms of Bad or Failing Automatic Shutdown Relay YourMechanic Advice
1helpful
Whats the codes p0685 an p0688 on a 2004 chrysler pacifica mean
P0685 CHRYSLER - Auto Shutdown Relay Control Circuit Failure
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible Causes
- ASD relay circuit is open or shorted
- Failed Auto Shutdown relay
- Failed ECM
Tech Notes
Check all the ECM fuses, if the fuses are OK try replacing the ASD relay.
P0688 CHRYSLER - Auto Shutdown Relay Control Circuit Low
The Front Control Module (FCM) has detected the supply voltage below an acceptable value
Symptoms
Possible Causes
- Failed ECM
Tech Notes
Have a 2004 jeep Cherokee that has a p1389 code in
gee 1, last year of Cherokee is 2001, so you meant Grand right??????
gee2, wont start or stalls, no other symptoms????? just 1 DTC, no others using a real scan tool? that be first huh?
Geewise 3, what engine, wow, wrong car, no engine or country.?
the FSM covers this, and the ASD has 8 ways to trip off line'
UP TO 8 ways , just like old wonder bread had.
answering for 2004 GC, (i actually look it up in the real book)
not google butchered DTCs.
P means power train, 1 means factory codes.
a 3 coin toss lands...
2004 GC, vin N, 4.7L v8 automatic,
it reads. verbatim.
Trouble Code: P1389
No Auto Shutdown Relay Output Voltage To PCM
Number of Trips to Set Code: 1
  • Catastrophicmonitor failure.
Trouble Code Conditions:
Engine cranking; and the PCM did not detect any voltage on the ASD Relay Output circuit to the PCM during the CCM test.
Possible Causes:
  1. ASD relay connector is damaged, loose or shorted
  2. ASD relay output circuit is open between the relay and PCM
  3. ASD relay power circuit is open (test power from Fused B+)
  4. ASD relay is damaged or has failed
  5. PCM has failed (nah)
it means, to me.
  • the relay is unplugged
  • or fuse blown "fused B+" (a top reason, world wide)
  • the relay is bad.
my buds ASD page,
http://www.fixkick.com/Jeeps/ASD.html
Where isthe auto shutdown relay on ford ranger
Its called an EEC relay, should be in the relay box or along the fender near the battery.
2helpful
P0688 2005 pt
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
Possible causes - ASD relay circuit is open or shorted (replace this relay first)
- Failed ECM (engine control computer)
I have a 2003 dodge dakota. 4.7l. I get codes p0685 and p0688. No start no spark. Relay is good. But voltage drops when using a voltage meter on one of the grounds in the pdc. Any live wire and that ground...
- Failed ECM
Tech notes Check all the ECM fuses, if the fuses are OK try replacing the ASD relay. P0685 DODGE Description Short or open in Auto Shutdown (ASD) relay circuit
P0688 DODGE - Auto Shutdown Relay Control Circuit Low
- Failed ECM
Tech notes Check all the ECM fuses, if the fuses are OK try replacing the ASD relay. P0688 DODGE Description The Front Control Module (FCM) has detected the supply voltage below an acceptable value
My 91 jeep wrangler 4.0 will shut down all power at all speeds from idle to driving on the interstate. I jumped out the auto shutdown relay and it works fine but i cannot find the auto shutdown switch to...
There is no switch. The relay gets a signal from the computer. If there is no signal from the crank position sensor the computer will not close the relay. If it runs with the relay bypassed, chances are good that the relay itself is bad.
1helpful
2000 dodge van 5.2 auto shutdown relay tunes van off as i am driv
the auto shut down relay is not like a fuse that can shut the engine off the name it has actually has not much to do with its function.. the relay is controlled by the computer .. its main function is to stop run-on and turns off o2 heaters power to coil and injectors if you had the key in the run position and engine not running your battery would dies faster than a drive in movie.. but anyway if your stalling and think its the relay failing just swap it with another one that looks the same from the PDC.. what you may have is a bad fuel pump or even a crank sensor have you had it scanned for codes? sometimes but not always you may have a code for lean upstream o2 if the pump is failing but not always.. and for the crank sensor you may have a crank shaft position sensor performance or cam/crank sensor code ..
Location of Auto ShutDown Relay for 1989 Jeep Cherokee
Auto shutdown relay and fuel pump relay are by the battery under a cover.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
