RELIANCE ELECTRIC WATER HEATER Logo
e
edward clarke Posted on Aug 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After pushing reset button,how long before water gets hot
Gene Haynes
Level 3:
  • Reliance Master 5,391 Answers
  • Posted on Oct 02, 2018
Gene Haynes
Reliance Master
Level 3:
Answers
5391
Questions
0
Helped
2605933
Points
14124
About 20+ minutes... full tank of hot will take longer.. put ear against tank and listen if it is heating
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3 Related Answers
woozie38
  • 608 Answers
  • Posted on Mar 21, 2010
SOURCE: hot water gets too hot trips off at tank then
It's time to replace your thermostat. Instead of maintaing the correct water temperature, the water is getting so hot it is acivating the safety circuit breaker. If this breaker were to fail, you could have a devastating explosion
A
Anonymous
  • Posted on Mar 08, 2011
SOURCE: Reliance 606 electric 40 gallon hot water heater
ECO reset button trips for several reasons.
1) Easiest thing without testing, is replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) If problem persists, then test elements.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) If problem continues, do full troubleshoot
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
robert
  • 2548 Answers
  • Posted on Aug 18, 2015
SOURCE: how long after pushing reset button,does water get hot
why did reset button need to be pushed. what caused it to trip. that may still be the issue.
Where is the reset button on a electric hot water heater Model # ME30H6-S45100 Serial # 1643103783645. I have no hot water and I want to check the reset button.
didnt specify unit--- generic answer --- on most where the thermostat and element connections are is usually a red reset button to push
1helpful
How long after pushing reset button,does water get hot
State Water heater pushed button to turn water down - all lights were lit initially.now no hot water - tried to reset - not resetting - help!
Which water heater do you have?
Is this gas or electric, tank or tankless?
What button did you push to turn water down??
Do you mean turn down water temperature?
What lights do you have that are lighting up?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Called and was told to change lower thermostat but yet again I had to go push red reset button on top panel to get it back on to get hot water. what should I do now?
You have electric water heater.
You have top and bottom panel, so water heater is 240Volt.
No hot water because ECO reset button tripped.
Water heater works correctly when reset button is reset, so electric power and circuit breaker are good. Water heater wiring is probably good.
Problem is most likely bad thermostat.
I usually replace both upper and lower thermostats.
If problems continue after replacing thermostats, then test and replace elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
I have a Rheem Marathon 105 gal. electric hot water heater. No hot water ....
Check 240 circuit breaker.
Open top cover on water heater and push in ECO red reset button.
If reset button will not reset, then replace thermostat.
If reset is not tripped out, then either upper thermostat is bad, upper element is bad, or water heater might be getting 120V instead of 240V.
If you have some hot water, then best suspect is lower element.
Upvote the help.
And take advantage of fixya expert assistance live.
2answers
We purchased a new electric hot water heater we installed it on a 220 line and we are not getting no hot water
check with a vom set on high voltage setting. for power... black wire to black wire,, white wire to red wire on heater ground wire to tank ..on 220v there is no neutral like on 110volts..check red reset button under top panel / control push on it resets it,,,
Hot water gets too hot trips off at tank then water gets cool and i push reset button and water gets hot again real hot thentrips off again
No hot water...where is the reset button on the 81vh40d hot water heater by Rheem
the reset is under the top cover, take the screws out and there will be a plastic sheild pull it off DO NOT TOUCH ANY WIRES push the reset button you should here it come on,, if there is any water present do not turn it on but find the source of water and fix or replace the water heater
Top Reliance Water Heaters Experts
john h
Paul Carew
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
