What is the mix ratio for a Johnson outboard motor?
Any Johnson outboard motor built since 1964 requires a 50/1 fuel ratio. Motors built prior to that date require a 32/1 ratio, with the exception of a few fishing motors built prior to 1955 that use a 16/1 ratio.
For minor tune-up. Remove, clean or replace spark plugs. Use Johnson recommened fuel additive and recommended fuel type. Replace lower unit grease. Spray clean carburetor. Check fuel line and filter. check water pump function.
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
