It was on the last cycle spin it stopped had pumped the water out but stopped spinning.
Lights that lit up were the 3rd and last on the wash cycle and the second orange in the middle of rinse and spin and the spin then a continuous beeping.
https://www.fisherpaykel.com/us/support/expert-tips/Fisher & PaykelFind Tips, Troubleshooting Information, How-tos, FAQs and Answers to Commonly Asked Questions about Fisher & Paykel Appliances.
also on Youtube
Most possibly be Error code 56,
Is common in 11 series machines & early series 12. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code, To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
When you start your machine is the water just go stop go stop, Just wait for the machine to display an error code on the wash progress lights and beeps constantly. It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch. Your error code will determine this. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
Red spin light = 1
2nd rinse light =2
1st rinse light =4
last wash light=8
4th wash light=16
3rd wash light=32
2nd wash light=64
1st wash light=128
Sounds like the water pump may be faulty. That would keep it from pumping the water out, which might keep it spinning in an attempt to empty the drum of water.
Water pumps are generally accessible from the rear, via an access panel. Check it for debris or a worn bearing. It should be obvious.
Hi just read your posting.Now does the machine drain the water out?Does the machine stop and beep and show a series of lights that are lit when it is beeping?If it does they will be in a row of 8 lights.Starting from left to right which lights are lit,Is it the 1st and 3rd or the 4th and 7th ---etc---?Please reply with additional information and I will be able to help you further.Looking forward to your reply.
Hi just read your posting.Does your machine drain the water out?Starting from left to right what lights were lit on the progress bar when it started to beep?Was it the 2nd and 5th or 3rd and 7th---etc---?Please reply with additional information on the questions and I am sure I can help you rectify this fault.
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
