computadora prendida insertar la conexion usb en algun puerto usb colocar el disco de instalacion en la unidad dvd y esperar a que la computadora lo instale ...listo
http://www.lg.com/de/service-produkt/lg-MCL1ULOGE# Its in german but you can change it to english or whatever after you find the right file to download.
Make sure the scanner usb and power leads are securely seated the drivers for the scanner might have been corrupted you might have to uninstall the scanner restart your computer then reinstall your scanner if your printer/scanner came with an installation disc the drivers could be on it you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver select properties again you will have the similiar options also have option to troubleshoot hope this helps
*be sure all your "Windows Updates" are up to date.
Once installed I had to go to the default directory C:\VistaScan to find the .exe file. The software booted right up! But, it said the device was not on. I simply pulled the USB out and put it back in and it worked perfectly.
I imagine you might have to start up vista scan and pull the USB cord in and out every time you reboot your machine, which is kinda a cheap work around. However, it is a way to "give it to the man"!! and I like that idea ;)
get the driver here: http://members.driverguide.com/driver/detail.php?driverid=119017&qint=1&action=downloadsplash&expcode=At82snaUidNtrCvtF7wFYmllar0f3+rewfY6ssl80AScYQmRqFJgCy+m73y4d8SpCguoP54d8tExCIOwz5WlwHGMxfRteepYfeukfqcwvGltSypGReOt6UR+YM62eOBr
go to UMAX 4100 scanner installation CD that comes with the scanner and find the setup.exe file and on it clik left mouse and then right mouse and choose properties and then choose "Install in WinXP-Sp2 compaitibility mode" ...Thats its . Then it will install in Visa and will work perfectly. Only when you startup the Vista it gives you some error message "incompitable Os" etc ..just cancells the message ..and your Umax 4100 Scanner will work perfectly.
