Building Materials Logo
A
Anonymous Posted on Aug 15, 2015
How many square foot of floor panels do I need to cover a room 12 foot x 6 inches x 13 feet in square eet?
micky dee
Level 3:
  • Master 3,015 Answers
  • Posted on Aug 16, 2015
micky dee
Master
Level 3:
Answers
3015
Questions
0
Helped
1061225
Points
8762
To convert your 2 dimensions to square feet you have to multiply them together.
12.5 x 13 = 162.5 square feet.
You do not give the size of floor panels you want to use
To find out how many panels you neeed, divide 162.5 by the square footage of the panel
eg, 12" x 12" panels are (1x1) 1 square foot so you would need 162.5 of them.
24" x 24" panels are (2x2) 4 square foot so you would need 41panels
1helpful
Will 51 cubic foot of foam insulation, cover 400 square feet of a wall?
That depends upon how thick the foam insulation is. That is the only way to compute from cubic feet to square feet.
To simplify, assume the foam is 1 foot wide by 1 foot thick by 51 feet long. That is 51 cubic feet of foam. If you slice the block lengthwise at 1 inch intervals, you get 12 slices, each 1 foot wide by 51 feet long by 1 inch thick. This is 51 square feet of coverage at 1 inch. You would be able to cover 51x12, or 612 square feet.
Increase the thickness of the slice to 1-1/2 inches, you only get 8 slices, or coverage for 408 square feet.
Any thicker than that, and you won't get enough coverage for 400 square feet.
How many square meters in 90,000 linear feet of 41.3" wide material?
First, we need to determine the number of square units in the Imperial system. We can choose to do the calculation in feet or inches.
Let's do it in inches first. There are 12" in a foot, so we multiply 90,000 by 12 to get 1,080,000 linear inches. Multiplying this by 41.3", we get 44,604,000 square inches. We can convert this to square feet by dividing the number of square feet by the square inches in a square foot. Since a square foot is one foot by one foot, or 12 inches by 12 inches, there are 144 square inches in a square foot. Dividing our previous answer by 144 will give us 309,750 square feet.
Converting to square metres. An inch is defined as 2.54 centimetres ("cm"). Thus, there are 2.54cm x 2.54cm in a square inch or 6.4516cm^2 in a square inch.
Using the 44,604,000 square inches we got above, and multiplying this by 6.4516, we get 287,767,166.4 square cm. There are 100 cm in a metre, so there are 100cm x 100cm in a square metre. So there are 10,000 square centimetres in a square metre. I get 28,776.7 square metres.
There are 3.280839895 feet in a metre. So there are 3.280839895 x 3.280839895, or 10.76391042 square feet in a square metre. Taking 309,750 square feet and dividing by the 10.76391042 we get 28,776.7 square metres.
Good luck.
Paul
2answers
My room is 13 x 12 how many square feet do I need?
13 x 12 = 156 square feet. However, they recommend getting 10% more to allow for staggering seams, trims cuts, and possible defective boards, so you should get at least 170 square feet.
2answers
HOW DO I CALCULATE THE SQUARE FOOTAGE NEEDED TO LAY A WOODEN FLOOR?
Hello, width x length,measure the largest portion of the room and if you have a small area like a alcove measure that also then add your totals up. hope this helps
PS I try to convert to feet
I have a 14 x 14 foot area how many square feet of flooring do I need
The general rule of thumb is to take the area of the room plus 10%. However, if you are not covering the entire area (say you are not going to floor underneath an island, let's say), you can deduct that area. 14x14 = 196 square feet + 10% (19.6 - say 20 square feet), means you'll need 216 square feet of flooring.
3answers
How much area is a square foot?
A square foot is by definition 12"x12" or 144 square inches. Measure your area in inches, multiply the length by the width and divide the total by 144 to figure the square feet.
How do I calculate square feet of a room for wallpaper
Measure the length and width of each wall, and then add up the resulting answers. So, if a wall is 9' tall and 12' wide, it is 108 sq feet. If another wall is 9' tall and 11' wide, it is 99 square feet. Your total would now be 99 + 108 or 207 square feet.
If you are doing it in feet and inches, you have to covert the inches to feet by dividing them by 12, since there are 12' in a foot. So with 3", divide 3 by 12 and get 0.25.
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
