Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Just cut the 2 wires to the switch and cut he insulation back and twist them together with a wire nut......use a switchable power bar to turn it on and off......I did this to a Realistic amplifier and it works fine...........
Hello Paul,
I think this model number should have a switch near or underneath where you plug in the power cord. Push that switch in and press the power on button after that.
unfortunately, if the drive is stuck, the only way to retrieve your disk would be to take the unit apart. Be careful though as this will void any warrenty. Make sure the set is switched off and unplugged before attempting this, be careful as even when switched off, some tvs can still hold a lot of voltage.
Hi, two things.. Either your remote needs new batteries, or you need to switch off your tele and allow it to reboot for a few minutes before switching it back on, I hope this helps
