Unscrew all screws on back (9) and bottom (4), noting which go where (all the ones on the back are the same, the ones on the bottom are different). Use fine screwdriver to pry off front, remove bottom. Remove screws on bracket at top of oscillator screen and fan.Remove screws at bottom of oscillator screen. Lift off oscillator and lift fan upwards after loosening small screw that holds it to motor shaft.
You can vacuum/brush/wash oscillator screen and fan with hot soapy water, vacuum and wipe back casing and around motor, let parts air dry and reassemble in reverse order.
