Lenovo ThinkPad X60 Tablet PC Logo
How to replace charger port on Lenovo tablet?
Charger port is broken on bottom and will rarely connect to charge battery
2 Related Answers
kjamison2002
MatchstalkMan
  • 261 Answers
  • Posted on Apr 13, 2015
SOURCE: Charger port broke on Lenovo a3000 tablet
Find someone close to you who does small electronics repair. Tablets are tricky and the most expensive part is the labour cost in getting the unit apart carefully and safely. I have repaired tablets and computers to component level. I also happen to be a qualified electronics engineer.
steves_here
steve
  • 1692 Answers
  • Posted on May 11, 2016
SOURCE: My lenovo tablet is not charging it appears as if the charger port may be loose??
Hi Laura, The link below is a YouTube video showing how to fix your phone, Also there's video's down the right side of the link that may help as well....CHEERS..
lenovo IdeaTab A1000 Power on and Charging Failure Issue dead after low...
2answers
Battery port
Depending on how hot you may be right. It is normal for the battery to heat up when you charge it. I have an RCA tablet that while the charge port (which doubles as the micro USB) fits tight and the battery still heats up to the point where it is hot to the touch but not to hot to hold. If your charging port is broken then the tablet will nont charge at all. If it is loose and not getting good connection then the battery will charge intermittently. Again either of these issues will not cause the battery to get abnormally hot. However, if there is an issue with the battery itself then it may get too hot. If so the charging circuit thermistor should cause the battery to stop charging.
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Dragons touch tablet wont charge up even when charger connected
its either you need a new charger (assuming your charger is broken) or you need a replacement on your charging port (it can be costly, try replacing a new charger)
Keeps saying connect charger even wben charger connected.iam trying to charge tablet
probably your charger is broken or your charging port is broken. either way, if the charger is broken, its cheap to replace. if the port is broken, its cost a bit more
2answers
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
1helpful
2answers
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
2answers
Hisense sero 7 lite
check wires....if it's not broken or damaged.....
check if cable is not broken around connector area or around plug...
check if you connected connector deep enough while charging..... check if connector on tablet is clean, if not, try to clean it, remove dust from inside
Top Lenovo Tablets & eReaders Experts
NOEL
NOEL
Paul Bade
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
