Interesting Lets try camming from your mobile device to see the washer! I like the idea. would be better than sending out a tech to look right! So, how do we do this and maintain annaminity! I am not scared heck! I have no reason to lie! so lets do this! Do you know how to add a video is cool Looks like how you add the video you click add video, look down below this panel.. Use your smart phone to download or copy the link.Nice, you download your video from you smartphone to your youtube channel! Sounds simple enough, send to luckysafehaven on youtube. I can look at it! Yes I can help you identify isolate the problem! What is the cost to replace this part can you do it your self? There are plenty service companies with the experience! I will take time to investigate more upon request!
If it's still under warranty. Go to the store where you bough from
and ask them about. They'll ask an authorize from the factory and the will find some one to fix for you.
Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch
If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch
If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor
Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys
The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission
The transmission could have either of these problems:
Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
avanti is on a metric system and depending on where you are you might not be on metric thats why they don't fit,, one has a fine thread the other is course, you will need ot go to an actual plumbing supply house, they have the converson fittings,, don't waste your time at home depot
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
