Sanyo DP42746 42 in. Plasma Television Logo
G
Gary Posted on Aug 13, 2015
Sp Gupta , Hi , I applied the 13 volts to the test port on the sanyo dp42740 , but still the same thing .
Ive replaced the digital board , the power board , the main board , Wondering how to test from here .
1 Related Answer
gopakumarg43
  • 76851 Answers
  • Posted on Jul 22, 2015
SOURCE: SANYO DP42740 DIGITAL CONTROL BOARD , can it stop the tv from powering up .
Yes. If it has shorted component/s. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
I replaced the power board on my Sanyo dp42740 but it still does the same thing the TV will click so power up green light in front comes on then goes right back off what else could cause this
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
1helpful
I have a Sanyo dp42740 plasma TV , the green light on front comes on for about 2 seconds and goes off. what is it?
Hi Gray,
Please try giving 13V from external source. When we exhaust all the options of changing boards we try such things to get the set working. I hope it helps.
Good luck
DP42740 plasma TV. Why won't it turn on?
Order your boards from the manufacturer of the TV go to their website they be happy to send them and I will get a refund from shopjimmy
What causes the sanyo DP42740 plasma tvs green power light turn on and off?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Where is located the fuse in a tv sanyo model No. DP42740
There are several fuses on the power supply board.
The main one is right next to where the cable from the AC connector is on the power supply.
BTW you may want to check these listings too:
http://www.coppelltvrepair.com/search?q=DP42740
(although if you are looking for a fuse that probably means totally dead TV and if that;s the case then you do not need a main board repair)
What is the usb for on the sanyo DP42740
USB port is located on the back of unit next to the Antenna input. See page 6 of: http://us.sanyo.com/dynamic/product/Downloads/DP42740%20(355--)-25942323.pdf
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
