Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012 Logo
A
Anonymous Posted on Aug 12, 2015
How do I replace the pressure hose? - Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012
How to change the power steering pressure hose on a 1995 Buick Regal gran sport
How to Remove a Power Steering Hose the Easy way, Tool ...
? 7:49
www.youtube.com/watch?v=OVBFrMcmV7Y
Dec 12, 2013 - Uploaded by Artistry Photography How to Remove a Power Steering Hose the Easy way, Tool Review ... The removal of this power steering pressure hose is a hard job but the ...
Replacing A Leaking Power Steering Hose - YouTube
? 2:38
www.youtube.com/watch?v=l1boEHtawcM
May 12, 2010 - Uploaded by Scotty Kilmer replace the whole hose assembly, they hold 1600 psi pressure, you can't .... i was told i need a new power steering pressure hose for my 2003 .
1helpful
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Install high pressure hose. Cannot get shaft of hose fitting to go deep enough into fitting so retaining clip will engage
There are several different configurations for these fittings. If you bought a generic replacement hose, it may have a different fitting than what is on the machine. May have to replace the fitting on the machine, or buy a hose specific to your pressure washer.
1helpful
Install replacement high pressure hose
If you are replacing the hose because it burst you might contact the manufacturer. Mine, of a different brand, burst and they sent me a new pressure washer saying that it was very difficult to install a new hose. They had a lot of problems with hoses from China.
How do i install power steering hose on a 1991 lexus 400
If you notice problem with power steering,the hose has to be inspected,if its faulty it has to be replaced.
For your help,i provide you with few solved helplinks showing how exactly to replace power steering hose:------
How to Remove Power steering Pressure Hose ?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-power-steering-pressure.html
How to replace power steering pressure hose?
http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-pressure.html
These will help.
Thanks.
I have a simpson G3000 pressure washer. The small high pressure line from the pump has developed a leak, (it's about 18"s) Do you have a part number I could use to get a replacement, or point me...
You can use a universal hose for replacement. This hose should not be under high pressure (usually inlet water hose pressure). This is a bypass that is used when you release the trigger to wand. Look closely at the brass fittings of the hose, sometimes they can be reused by removing the clamp and cutting off the rubber part. Use automotive rubber hose (suitable for hot water system/radiator )or black pressure hose from Lowes (sold bulk) that will fit snugly on the barb and use simple clamps. You can make new hose by buying barbs and hose from Lowes or hardware/plumbing store. Good luck
5helpful
Need to replace high pressure power steering hose on 2004 Monte Carlo SS. Need tips to effectively do the job myself. Tools needed, tricks to make the job easier, what not to do...etc. Thank yiou so much...
Power Steering Line/Hose: Service and Repair
Pressure Hose
Power Steering Pressure Pipe/Hose Replacement (3.8L)
Removal Procedure
1. Place a drain pan under the vehicle.
2. Remove the accessory drive belt.
3. Raise and support the vehicle. Refer to Vehicle Lifting.
4. Remove the tire and wheel assembly.
5. The power steering pressure hose is the lower hose at the power steering gear.
Remove the power steering pressure hose from the power steering gear.
6. Remove the power steering pressure hose from the power steering pump.
7. Remove the power steering pressure hose from the clamps on the power steering gear.
8. Remove the power steering pressure hose from the vehicle.
Installation Procedure
1. Install the power steering pressure hose to the vehicle.
2. Install the power steering pressure hose to the clamps on the power steering gear.
Notice: Refer to Fastener Notice in Service Precautions.
3. Install the power steering pressure hose to the power steering pump.
^ Tighten the fitting to 27 Nm (20 ft. lbs.).
4. Install the power steering pressure hose to the power steering gear.
^ Tighten the pressure hose fitting to 27 Nm (20 ft. lbs.).
5. Install the tire and wheel assembly.
6. Remove the drain pan from under the vehicle.
7. Lower the vehicle.
8. Install the accessory drive belt.
9. Fill the power steering system with power steering fluid.
10. Bleed the power steering system.
11. Inspect the power steering system for leaks.
32helpful
2answers
My power steering pressure hose has a leak.
i pERSONALY WOULD REPLACE IT MYSELF EVEN WITHOUT MY 30yrs Of Experience in this Field. I have Enclosed Instructions for you to use. PLEASE dont Forget to RATE me As MOST folks DONT remember to that is how WE Get our Ratings such as GURU THANK YOU and Good Luck On The Job, Dont PAY a dime If YOU CAN > D I Y
REMOVAL PROCEDURE
  1. Remove the power steering pressure hose (2) from the power steering pump (1).
  2. Raise the vehicle on a hoist. Refer to Vehicle Lifting.
  3. Remove the front exhaust pipe, automatic transmission only. Refer to Intermediate Pipe Replacement in Exhaust System
  4. Remove the power steering pressure hose (1) from the power steering gear (3).
  5. Remove the power steering hose retainer (2).
  6. Remove the power steering pressure hose (1) from the vehicle
    1. Install the power steering pressure hose (1) to the vehicle
    2. Install the power steering hose retainers (2). NOTICE: Refer to Fastener Notice in Service Precautions.
    3. Install the power steering pressure hose (1) to the power steering gear (3). Tighten the fitting to 27 Nm (20 ft. lbs.).
    4. Install the front exhaust pipe, if removed. Refer to Intermediate Pipe Replacement in Exhaust System.
    5. Lower the vehicle.
      1. Install the power steering pressure hose (2) to the power steering pump (1). Tighten the fitting to 27 Nm (20 ft. lbs.).
      2. Bleed the power steering system. Refer to Bleeding Power Steering System in Service and Repair of Steering.
3helpful
2answers
Kenmore 70 series washer model 82870120 will not stop filling
you need to replace the water valve. This is a common problem and a very easy fix. You can order the part at sears.com via model number and also see a breakdown of the machine and how to put it in.
4helpful
2answers
Water keeps flowing non-stop with my old Kenmore washer
Check the pressure switch and the pressure switch hose.
Remove the end caps on the console and remove the 2 screws that hold it down. Pull slightly from the bottom of the console and flip it up. On the left side you should see the pressure switch (water level switch) with a few wires and a small hose connected to it. The hose should be connected between the pressure switch and the tub. In most cases the pressure switch hose sometimes falls off over time due to vibration.
Replace the hose if it is damaged. If there are no visible holes or cracks in the hose, try trimming 1/4" off each end of the hose (pressure switch side and tub side) and reconnect them making sure to push hose ends securely onto connections. This is done because the hose sometimes stretches at the connection points and you will lose air pressure inside the switch, therefore the water will never shut off.
Alternatively you can use small clamps on each end.
If this doesn't work, check the function of the pressure switch by attaching a small hose to it and blowing lightly into the pressure switch while the machine is filling. You should hear a click and the inlet water valve should turn off. If it doesn't turn off you may need to replace the pressure switch or if the machine fills even when it's in the off position replace the inlet water valve.
Top Greenworks Garden Experts
Jay Finke
Jay Finke
john h
Are you a Greenworks Garden Expert? Answer questions, earn points and help others
