<p>Barcode Scanners Symbol read and translates the barcodes on
merchandise. The scanner translates the bar code symbols on the label says the
price of the item and merchandising information. Traders use the symbol bar
code scanner to identify their merchandise. A programming error in reader bar
code symbol will cause confusion and may lead to loss of money. Troubleshooting
barcode scanner symbol allows you to identify bugs and find solutions to
errors. <br />
<p><br />
<p>1. Remove the installed fonts from the reader bar code
symbol. The sources of such capacity to disrupt the functioning of your bar
code scanner. Press the "Menu" button on the scanner bed and press
the "Select" option when the source is highlighted. Press the Delete
button to remove the sources of the sample. <br />
<p><br />
<p>2. Close the bar code scanner Symbol with a source of
energy. The scanner has a power cord can plug into an outlet. If the scanner
runs on batteries, the battery is fully charged before using the scanner. <br />
<p><br />
<p>3. Move the scanner closer to the bar. The symbol bar code
scanner cannot calibrate the bar if you wrong position. Place the scanner
directly over the bar and wait for the scanner to read and transmit the code. <br />
<p><br />
<p>4. Wait until the bar code scanner symbol to complete the
boot. The symbol bar code scanner is initialized when the USB cable is
connected to the computer. Initialization requires a short period of time to
complete the process. Let the bar code scanner symbol to be idle for 4-5
seconds before you first scan an object. <br />
what type of scanner? Try to remove the usb cable then restart your pc, after restarting plug again the cable then look at the system tray if the system is installing the scanner, if not unstall it then install again after rebooting.
It depends on whether you are using a keyboard wedge or a serial connection. Use 123Scan or MCL to make a change to the ADF file that tells the scanner what to do. Then you will have to upload the file to the scanner.
Appending an "Enter" to a scanned bar code (Keyboard Wedge connection)
Scanned bar code data 04843100Criteria 1 Code type = Any Criteria 2 Code Length = Any Length Action 1 Send all that remains Action 2 Send Value Keycode = 7013 <Enter> (String field must be empty)
Output after ADF rule 04843100<Enter>
Note: To have an ADF rule applied to all scanned bar codes, leave the criteria unspecified (Code Type = Any and Code Length = Any Length).
Appending a "Carriage Return Line Feed" to a scanned bar code (serial connection)
Action 2 Send Value String = \0D\0A
Note: Keycode value is ignored when string field is populated.
Output after ADF rule 04843100<Carriage Return Line Feed>
could be the component scanner inside of the minolta , it will need to be tested to determine if the scanners components or a wire strip is causing the problem or the component scanner its self , it sounds like a section of it is out so it will not see anything ------ ---------- in that section
The Kodak 3500 scanner series is probably the best scanner ever made, but NO, it doesn't read anything! Think of it as a digital camera. It only takes pictures. All OCR, ICR, BAR Code, etc. has to be read by software. Your software looks at the images and pull any info that it has been designed to detect off of that image. Some older scanners had built in bar code and patch code reading, but more and more, the software now does it, usually in conjunction with a Kofax card in the PC.
