Sometimes it charges at 14 v and other times it charges at 8 v for a little while and then starts charging again. When not charging the exhaust pipes get red hot and it does run right.
The battery is good. It stops charging while riding then it starts again.
Check to see if the exhaust is exiting the rear tailpipe. Could be a plugged up catalytic converter. Or some sort of obstruction in the exhaust system....
Has the alternator been replaced . alternators come with different amps . and if the jeep came with a low amp and is replaced with a high one would cause over charging.. also the ecu controls the charging
try removing the airbox on the side. Cup your hand over the inatke while cranking the motor. Do that for a couple of motor rotations. Once you've done that try restarting it without cupping the intake. Sometimes it takes a little extra suction to charge the engine with fuel or the carb isn't able to draw enough of an initial charge to start it. If that doesn't work hold your finger over the exhaust tip while cranking and release it while still ccranking it over. A couple of times doing that and she should fire up. If that doesn't work then I would check to make sure you are even getting gas to the float of the carb at all.
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
1 - Remove the turbocharger intake tube
2 - Disconnect the charge air cooler inlet pipe
3 - Remove the push pins on turbo cowl
4 - Disconnect the turbo VGT solenoid
5 - Remove the oil supply tube
6 - Using the special tool, remove the oil feed tube
7 - Remove clamp from the turbo down pipe
8 - Remove the clamp from the turbo inlet
9 - Loosen the exhaust inlet pipe-to-EGR cooler clamp
10 - Loosen the RH & LH exhaust inlet pipe-to-exhaust manifold nuts
11 - Remove the rear turbocharger mounting bolt
12 - Remove the front mounting bolts
13 - Position the turbocharger and remove the turbocharger drain tube
14 - Remove the turbocharger
If you cant do it with these instructions put down your wrench and take to a dealership for a professional to work on it
I can't see your exhaust system, but I do recommend that you have them show you the "why" of it. Generally the front pipe and the cat last a long time and generally don't need to be replaced very often. If the flanges are rusted and have failed there are "wrap around" replacements that can be used without pipe replacement. Most common is to change everything from the cat back. As I said, have them actually show you what is wrong...or take it to another shop and without telling them the original findings, have them look at it!!! Since there is very little involved except a visual inspection, most shops will not charge or will charge very little for this.
Perfectly normal. Starting with the 2005 model year, light duty full size pickups and
utilities are equipped with a new Regulated Voltage Control (RVC)
system. This system reduces the targeted output of the generator to
12.6-13.1 volts when in "Fuel Economy Mode" to improve fuel economy.
The generator may exit "Fuel Economy Mode" if additional voltage is
required. This will cause the voltmeter to fluctuate between 12 and 14
volts as opposed to non-regulated systems that usually maintain a more
consistent reading of 14 volts. This fluctuation with the RVC system is
normal system operation and NO repairs should be attempted.
