Car Audio & Video Logo
Jammie Davidson Posted on Aug 11, 2015
How do I hook up 4 10 inch mtx old school?
Can I put them in one box. they r 4 ohms each,
Kelvin
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Nov 14, 2015
Kelvin
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
1536
Points
20
You can put them in one box you will need a good port hole if you do.How to build subwoofer box
this link is on how to hook up speakers Subwoofer wiring diagrams \
good luck
5 Related Answers
Rob C
  • 547 Answers
  • Posted on Jan 30, 2010
SOURCE: i have two four ohm
Wire the kickers in parallel -- hook the positive from each speaker to the positive on the amp, and the negative from each speaker to the negative on the amp.
This will present a 2 ohm load to the amp, and it's rated down to 2 ohms.
Anonymous
  • 24 Answers
  • Posted on Feb 24, 2010
SOURCE: Brutus amp output problem
must be a bad amp..have you tried bridging them maybe youre channels are out it happens even if its brand new...factory deffects
oldmanewtoys
Rick Rife
  • 414 Answers
  • Posted on Mar 09, 2010
SOURCE: Can you help with my wiring?
The more amp you are pushing the better. Better too much amp then not enough. How many watts per speaker? less then the amp I hope. When you need decibles the more air you push the louder it will be. Enclose in a MDFB enclosure or plexiglass and feed towards each other and port the box to the sides. This will cause some annoyance. We ran 2 rockforts @1000 watts and abtained 137dc before the back windshield blow out,,lol
Anonymous
  • 52 Answers
  • Posted on Mar 25, 2010
SOURCE: how do i wire a mtx 251d at a 2 ohm load
To wire up a 2 ohm load depends on the subs. You will either need 1 sub rated at 2 ohms or 2 subs at 4 ohms wired in parallel. This website will help.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41#results
You can also use 1 dual voice coil sub rated at 4 ohms wiring the same way you would the 2subs at 4 ohms. Good Luck
Anonymous
  • 11 Answers
  • Posted on May 17, 2010
i need more info about the subs ur runnin to help u
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Just hooked up mtx 500d mono amp and 12 inch sub worked for a 1/2 hour then sub quite and led on top of amp just flashes.
either ur ohm load is way off ur pos n neg might be touchin or more than likely u blew u sub is it scratchy when u push in the middle of the cone ? does it push in at all?
3helpful
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
2answers
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Wiring
Run a Jumper from coil 1 + to coil 2 + and a jumper from coil 1 - to coil 2 - and then run + from coil 1 to amp and - from coil 2 to amp. This will put your load to 3 Ohm and that will give you the most power. You could get more by going to 1 ohm but I don't think the mtx amps are stable at 1 ohm.
2answers
Fuses
Check the ohm measurement of the speakers make sure they are about the rated ohms.Check them UNHOOKED from the amp. (Useually 4 ohms.)
Try different subs.
HELLO CAN SOME BODY TELL ME HOW TO HOOK UP MY SYSTEM RIGHT I HAVE 2 AUDIOFONICS ADF-272 1200 WATTS AND A MTX 4501 CLASS D MONO BLOCK AND A MTX 801D KIND OF OLD SCHOOL IS LIKE 4 YEARS OLD AND HOW TO series...
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=4
HERE IS HOW YOU HOOK UP 1 SPEAKER TO 1 CHANNELM DO THE SAM E TO THE OTHER CHANNEL. MAKE SURE AMP IS IN MONO MODE,YOU DONT WANT TO PLAY UR SUBS IN STEREO.AS FAR AS THE BOX DEPENDS ON VEHICLE AND HOW MUCN SPACE YOU HAVE .TELL WAT MODEL CAR AND ILL ET BACK TO YOU. I NEED A FIXYA RATING PLEASE
Top MTX Car Audio & Video Experts
Jose Ramirez
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
