You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
DVD movies usually send out a digital signal, like dolby digital, and this requires a matching decoder in your receiver in order to hear anything. Regular CDs don't use dolby digital, usually. Check you receiver to make sure it can decode the digital signal, and check your optical or digital coaxial cable.
To resolve this issue, try one or all of the following:
The
Wave® music system is designed to play commercial CDs, CD-Rs,
MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs,
make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
The system may not be able to play certain CD-RW discs. Playability
is dependant on how the disc was recorded, including the format it was
recorded in and the actual disc used for recording. Note: iTunes
defaults to AAC as the encoding format. In order to use iTunes to make
CDs that will play on the Wave® music system, you’ll need to change the
format to MP3 How to Choose Import Options
Different brands of CD-Rs and CD-RWs use different materials which
may affect the ability of a player to read them. If you are burning
your own CD-Rs or CD-RWs, experiment with different brands of discs
If a commercial disc won’t play, check for scratches, fingerprints
or other physical damage. Try the CD in another player. If it still
won’t play, there may be a problem with the disc
Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
