With CEL and error codes U 0155 and P 0201. Injector is good. Rig runs flawless and dies no warning??
Please Help! 2005 Jeep Wrangler Engine Suddenly Stops While ...
www.wranglerforum.com/.../please-help-2005-jeep-wrangler-engine-sud...
Oct 11, 2009 - 30 posts - 17 authors
... suddenly stopped on my 2005 Jeep Wrangler TJ while I was driving. ... 20 seconds later, engine suddenly died exactly as it did last week.
electrical problem? shuts off while driving
Sep 29, 2012
Sudden loss of power
Mar 9, 2012
Speedo not working and dies randomly
Dec 4, 2011
won't start, won't crank
Nov 20, 2011
More results from www.wranglerforum.com
SOURCE: How to change alternator on 2005 Jeep Wrangler
Straight out of the repair manual:
REMOVAL
WARNING: DISCONNECT NEGATIVE CABLE FROM BATTERY BEFORE REMOVING BATTERY OUTPUT WIRE (B+ WIRE) FROM GENERATOR. FAILURE TO DO SO CAN RESULT IN INJURY OR DAMAGE TO
ELECTRICAL SYSTEM.
(1) Disconnect negative battery cable at battery.
(2) Remove generator drive belt. Refer to 7, Cooling System for procedure.
(3) Remove generator pivot and mounting bolts/nut (Fig. 2) , or (Fig. 3). Position generator for access to wire connectors.
(4) If equipped, unsnap plastic cover from B+ terminal.
(5) Remove B+ cable output terminal mounting
nut at rear of generator (Fig. 4), (Fig. 5), or (Fig. 6). Disconnect terminal from generator.
(6) Disconnect field wire connector at rear of generator by pushing on connector tab.
(7) Remove generator from vehicle.
INSTALLATION
(1) Position generator to engine and snap field
wire connector into rear of generator.
(2) Install B+ terminal to generator mounting
stud. Tighten mounting nut. Refer to Torque Specifications.
(3) If equipped, snap plastic cover to B+ terminal.
(4) Install generator mounting fasteners and
tighten. Refer to Torque Specifications.
CAUTION: Never force a belt over a pulley rim using a screwdriver. The synthetic fiber of the belt can be damaged.
SOURCE: i have a 2006 jeep wrangler unlimited with a 4.0
you need to find out why cylinder 5 is misfire,plug,wire,etc
code po305
SOURCE: 91 Jeep wrangler New everything idles rough, no Power then dies
you check for miss how is compression
SOURCE: 2005 Jeep Wrangler Unlimited cruise control will not engage.
check the vacuum line on the right side of the engine. There should be an elbow connector connecting the line to the engine. Does interior fan only come out of the defroster vents by chance?
SOURCE: where is the wiper motor on a 2005 jeep wrangler
Hello. The wiper motor is right at the base of the wiper. here is a link to a great series of sites for Jeep owners. enjoy. http://pdfdatabase.com/index.php?q=jeep+wrangler+repair+manual+wiper+motor+diagram
