The ice maker and water dispenser was working fine a few days ago. Now within the past few days the water dispenser worked but you had to push it several times to get response, but now the ice maker does not work and the power indicator on the ice maker is not lit no power at the ice maker?
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
SOURCE: ice maker
I hate to say this but from experience on LG icemakers if the fingers aren't turning or the if you have the flextray model the only fix is a new icemaker. Make sure the fill tube to the icemaker is not frozen also.
SOURCE: water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position. Only way to tell is to pull the bottom kick panel out and look for the water line disconnect. Separate the line, close the door and try to draw water through the dispenser. If the water comes out of the disconnected line, then the water valve is good.
#2 if water is coming out of disconnected line, then the problem is in the freezer door. There is a heater that keeps the water line from freezing inside the freezer door. It is not repairable!! The freezer door has to be replaced.
SOURCE: Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker. Try this. Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button. Press and hold this button for 12 seconds to get it to force extract. This will confirm that the motors will work and push the ice cubes out. Afterwards, let it run by itself. If it still doesn't make ice, you will need to replace the icemaker.
SOURCE: ice maker freezes up
It's likely you have your freezer to cold, Try reducing the setting on that. If that doesn't work you might wanna check your freezer and make sure it's not thawing and then freezing again, you might have a problem with your fridges thermostat.
SOURCE: LFC20760ST LG bottom drawer freezer.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
