1995 Blazer rear speakers not working.NAPA shows a relay for speakers.
Would this be my problem ? if so where is this relay located ?
1995 Blazer rear speakers not working.NAPA Part# AR606SB
Stereo Speaker Amplifier Relay/Stereo Speaker Relay/Stereo Wiring Relay OEM#12065125
The wires provided for a radio system are as follows:
yellow = hot with ignition key ON
orange = hot from BATT at all times
Grey = dimming power from instrument panel
Black = ground
Harness Wires provided for the speakers as follows:
Left rear speaker = +brown -yellow
Right rear speaker = +dark blue - light blue
Left front door speaker and tweeter = +tan - grey
Right front door speaker and tweeter = +light green -grey
Note: connection colors at the speaker location differ as noted:
Right front door = +brown -yellow
Left front door = +brown -yellow
All other speaker connections are consistent with their harness colors.
On my expedition it is located behind the spare tire in front of the fuel tank. Small bracket holding it up there. If you go to a CARQUEST/NAPA/Oreilly parts store they will be able to show you a picture of where it is.
If your 1995 Chevrolet Blazer shows code P19DA, it means that there is a signal problem between the fuel pump and the PCM. This may have happened because you have a burned fuel pump motor, or the float meter of the fuel pump has a burnt wire.
Check the fuel pump relay, if malfunctioning, inspect the ground circuit to and see if the resistance is accurate. If it appears to be damaged, remove the fuel tank, taking out the pump, and replacing it with one that works.
Hi there: Check this on 1998 Chevrolet S10 Blazer Car Stereo Radio Wiring Diagram:
Car Radio Constant 12v+ Wire: Orange Car Radio Switched 12v+ Wire: Dark Green Car Radio Ground Wire: Black Car Radio Illumination Wire: Gray Car Stereo Dimmer Wire: Violet/White Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Tan Left Front Speaker Negative Wire (-): Gray Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Dark Green Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Dark Blue Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps; also keep in mind that your feedback is important
and I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Hi natgonzo, your Blazer doesn't use a starter relay, it only has a starter solenoid which is attached to the top of the starter motor. Hope this helps.
The fuel pump relay in my blazer is located in the rear of the glove box which means you have to clean out all of the maps and other junk to get to it. There is a plastic cover that has to be removed to expose the relay which is the right side of the two present.
You can tell if it is operating when you turn the ignition key to "ON", the relay will click and you should hear a humming sound as the fuel pump energizes.
2000 Chevrolet S10 Blazer Car Stereo Radio Wiring Diagram
1995 Nissan Pathfinder Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Pink Car Radio Switched 12V+ Wire: Blue Car Radio Ground Wire: Gray Car Radio Illumination Wire: Red/Blue Car Radio Dimmer Wire: Red/Yellow Car Radio Antenna Trigger: N/A Car Radio Amp Trigger Wire: N/A Front Speakers Size: 5′ x 7′ Front Speakers Location: Doors Left Front Speaker Wire (+): Pink Left Front Speaker Wire (-): Blue Right Front Speaker Wire (+): White Right Front Speaker Wire (-): Black Rear Speakers Size: 5′ x 7′ Rear Speakers Location: Roof Mount Left Rear Speaker Wire (+): Light Green Left Rear Speaker Wire (-): Purple Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink
