HP Photosmart C4580 All-in-One InkJet Printer Logo
Posted on Jul 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I get a Windows2000 HP-C4580 driver
How can I get a Windows2000 driver for the HP-C4580 ?
Disk only contains XP & Vista, & MacOSX.
HP website W2000 link yields package that does not run on W2000.
Tia, doug fromoz
Anonymous
Level 2:
  • Expert 94 Answers
  • Posted on Jul 12, 2009
Anonymous
Expert
Level 2:
Answers
94
Questions
0
Helped
21447
Points
259
I think drivers for 2000 and XP are the same. You can use the drivers for XP or sometimes, drivers are already built-in to XP.
Usb connectivity problems between packard bell computer and hp c4580 printer- help please!!!
Dis connect printer,go to control panel,un install/remove installed drivers. In my computer properties,go to device manger check USB controller, if found printer device, un install it. restart the system,run driver CD, connect printer USB cable when system searching for the device,check for the printer recognition, do rest installation process..
Can,t get printer to work need to configure and get driver to work
Computer off, Photosmart C4580 OFF, and unplugged from power. Disconnect the USB cable from it to the computer.
Turn the computer on.
Remove all associated HP software for the Photosmart.
Control Panel > Add or Remove Programs.
When the list populates remove all HP software for the Photosmart.
When finished close all windows, go back to your desktop screen.
Restart your computer.
HP Support > HP Photosmart C4580 > Main support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3418707&lc=en&cc=us&dlc=en&lang=en&cc=us
Click on the heading - Software and Driver Downloads - in the list.
(Right side)
Select your Operating System. Click on the blue down arrow, to the right of the box with Select in it.
Click on the Operating System you are using.
(If you have Windows XP Home or Pro, click on Windows XP.
Unless you have Windows XP Pro that states it's 64-bit )
I'm going to use Win XP as an example, because the O/S you are using wasn't mentioned.
After you click on your O/S, go to the right, and click on Next in the blue rectangle.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3418707
Using Windows XP for an example I would click on the + sign,
to the left of, Driver - Product Installation Software (2)
The drop down list shows;
A) HP Photosmart Basic Drivers
56.03 MegaBytes in size. (56.03MB)
B) HP Photosmart Full Feature Software and Drivers
149.41MB in size.
I recommend downloading B)
Get the full package.
Click right on the blue heading -
Scrolling down to the heading - Details and Specifications, and further down to the sub-heading - Compatibility, we see this software is compatible with XP and Vista.
Shows it to be compatible with Windows Vista, and both versions 32-bit, and 64-bit.
Only shows it to be compatible with Windows XP in a 32-bit version.
If it is good for a Vista 64-bit O/S, I'm going to go out on a limb, and state it will work with Windows XP Pro 64-bit.
To download the file click on the blue file name -
PS_AIO_04_C4500_USW_Full_Win_enu_120_210_NB.exe
( [1/1, 149.41m]
This means Page 1 of 1, and the size is 149.41 MegaBytes )
After you click a small window will come up.
Opening - and the file name.
Click on - Save File.
After you click another small window will come up. This time on the left side.
In the heading of this window, tells you where the file will download to.
It may have Desktop, or My Documents, or Downloads, in the wording.
[ Desktop, or Documents, or Downloads, for Vista and Win 7 ]
Write this down, and the file name. (File name; so you can find it later)
Desktop: The file will be on your desktop screen.
My Documents: Click on Start, then on My Documents.
[ Windows logo button, then Documents, for Vista and Win 7 ]
Downloads:
Click on Start, then My Documents. DOUBLE-click on Downloads.
[ Windows logo button, then on Documents. DOUBLE-click on Downloads, for Vista and Win 7 ]
When you see the file name DOUBLE-click right on it.
Follow the easy instructions.
(Next, Next, and Finish)
Plug the USB cable of the Photosmart back into the Advent laptop.
Turn the Photosmart on.
After a few seconds, (After all of your Start-Up menu items are loaded, really), a pop-up should come up out of your system tray;
"Found new hardware"
,and perhaps another one,
"Found HP Photosmart C4580"
Post additional questions, or to have me clarify anything I have stated, in a Comment.
Regards,
joecoolvette
[ Why remove the software, then reinstall?
1) I don't think going to Add or Remove Programs, and clicking on - Repair, for the HP Photosmart software, will do any good.
I think there are too many files corrupted, and the software needs to be reinstalled in full.
2) You may get a driver conflict, with having part of the old HP software still there, and then reinstalling new software.
(Probability is pretty low, but why take chances, or have to do it all over again? )
My HP Officejet 4500 all in one printer, fax, copier, and scanner is acting up. It will not let me scan, it displays the message "There is no computer connection", however i checked the usb as...
A method to solve this problem Use the official HP Diagnostic Utility Scanning problem (Default for XP) Printing problem (Default for XP) If you are not using XP, just select another version in the link below Software & Driver Downloads
More for HP Photosmart C4580 All-in-One
Since there are clear instruction in those website, so I won't type it here.
Can't Help Much, But Effort Paid.
2helpful
I accidentally uninstalled my HP Photosmart C4580 Printer and do not have the originally software disk to reinstall it. Is there any way I can reinstall without the disk?
You can download the installation driver and software from manufacturer's support website by clicking this link
On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu and click the "Next" button.
The list of available drivers will load only after selecting the operating system of the computer.
Then download the "HP Photosmart Full Feature Software and Drivers" package.
Hope this solves your problem. Thanks for using FixYa
I need the driver for this camera; What do i need to do?
Hello bigmac - These cameras are detected by Wind7 & MacOSX according to their reviews.
And they also work on Vista & XP & 2000.
But drivers can be found on
http://driverwhiz.com/drivers-en?brand=Webcam&logo=Webcam&subid=1001-us-en-00000000007&gclid=CMzKmfTQzaYCFcULfAodrDsCNA
There were several driver sites found on (www.google.co.uk) -- Ray
2answers
I have lost the installation disc for my photosmart c4580 printer,can i download from the web
You can download the installation drivers and software from manufacturer's site by clicking this link
  • On the page which opens, select the operating system (Windows Xp/Vista..) of your computer and download the appropriate drivers and software from the next page which opens..
Hope this solves your problem. Thanks for using FixYa.
Cannot find my installation cd for hp photosmart C4580
You can download the required installation drivers and software from manufacturer's site by clicking this link
On the page which opens, select the operating system (Windows XP/Vista/Windows 7..) of your computer to download the appropriate drivers and software.
5helpful
Drivers for mac
Unfortunately Disney has made the Pix Micro Digital Camera's only Windows2000, XP & Vista Compatible.
Here is the system requirements take from Disney's website for their Pix Micro Digital Cameras
System Requirements:
  • Windows 2000, XP: 300 MHz or faster processor, 128 MB of RAM
  • Windows Vista: 800 MHz or faster processor
  • 300 MB free hard disk space
  • USB Port
Out of all of the feature Pix Micro Cameras they feature on their website, not one supports the Mac OS X system platform.
- Mactechtrainer
Sr. Mac Support Specialist
Driver for HP Photosmart C4580 All-In-One
i checked hp website and there is nothing for 2003 i see vista, vista 64, xp ,xp 64, win 2000, and mac but nothing more
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Can install hp photosmart c4580 to mac or windows vista. any ideas, what am i doing wrong
Do you have the newest drivers. Perhaps your disk only contains XP, and OS x 10.4 drivers? and you may be using 10.5?? XP drivers certainly won't work on Vista, not sure about the newest MAC.
Just guessing, try the latest drivers from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3418707&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
k24674
Grand Canyon Tech
Grand Canyon Tech
