I have the Generac a unit Model # 004582-2. Spread the gasoline engine. To make a wind generator. I can not use the same voltage regulator, because the transducer, or its control module is not used. Which would be generic voltage regulator compatible with the generator? Thank you!!!
SOURCE: Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
SOURCE: generac portable generator over voltage even with new control board and regulator
is engine running at 3600 to 3700 rpm at full load. most small engines run at this speed.you can buy a small tach on ebay TINY TACH.. you have to know what the engine speed is
