Assuming it is a pSr630 keyboard then there are 2 ways to connect depending on the computer you are using. The 630 uses 5 pin din midi in and out.
1) If you wish to connect to USB then you will need a USB midi interface such as
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=11173
or
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=5894
2) If you are connecting to a desktop with a 15 pin socket you can use a cable
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=18808
Your software then should recognise the input type in use and allow you to connect it accordingly.
