Use the USB cable and follow the instructions in the user manual. You can download the manual and updated software from here:
http://roland.com/support/article/?q=downloads&p=BR-900CD
I hate to say it, Sandra, but that problem usually doesn't involve an easy/cheap fix. I run a 1200 here, so I know from whence you speak. If this is an "under warranty unit", I'd box it up and swap it out.
BUT, if not, and you're any good at dis-assembly/re-assembly or know someone who is, I HAVE fixed problems like this with the "pressure" method. It worked on a Chevy digital dash that was blanking out on me and a couple music keyboards.
Power it down and unplug the power cord, dis-assemble it to the point you can see the board that feeds the display. Very carefully plug the power cord back in and power it up. While avoiding touching any of the boards or connections with your bare hands/fingers, use a pencil eraser and lightly apply pressure to different spots on that board until (maybe) the display lights - indicating a loose connection; probably a bad solder joint in that area. Trying to repair it would probably fry it, unless you're an ace solderer.
Now, the trick is to remember that spot, use a piece of non-conductive material, like a small wad of electrical tape big enough that it would apply a similar constant pressure to it at that point once it's re-assembled. I know - sounds bizarre, but I've made it work where soldering was impossible without a professional teardown.
If it does not power up, it is likely going to be a faulty or severly dirty switch contact or a failed capacitor in the power supply. A shot of contact cleaner is usually enough to rectify the first issue, The second issue you need to locate the part at fault and replace it.
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
