I was removing the bulb and it shorted out. think I blew the fuse. Exaust fan doesn't work either since short out.
SOURCE: Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid. This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller. This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on. If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: lights and fan quit working
there are fuses inside the microwave but there not the kind you would have in the house,,unless you can buy them it cant be fixed by you,
SOURCE: Tried to replace the surface light bulbs on my
Yes you should replace the fuse which in the control department. You must remove the cover which is one unit the top, left and right panel. Also sometime the bulb holder wires might have be loose or burned out and been disconnect so this have create an open circuit. So you can have a visual check of these wires but since you have the oven panel removed have a check of loose or overheated wires. Take care to remove electric plug and avoid come in contact with the magnetron capacitor since this can evacuate instant high voltage and might burn your hands, and this hurts very bad for more than a week. We have a link with the parts layout of your microwave which can help you.
SOURCE: I have a hotpoint microwave replaced the hood
I expect you will find you now have a short circuit bi polar switch. It means that as long as there is power to the unit, it will be on permenantly. It is part of the control panel.
