Question about Tablets & eReaders
What does authentication error mean when I try to connect to my wifi?
My home wifi connection keeps showing authentication error when it tries to connect. I can't get any wifi connection.
  • 938 Answers
You need to input the authentification code which was supplied with your router.
Posted on Aug 09, 2015
SOURCE:
Trying to connect to wifi. says connecting and authenticating. show reception to be excellent but will complete connection
Reset your wifi and device your trying to connect with :) Try again... see how it goes
May 07, 2017 | Tablets & eReaders
My new Nexus 7 wont go past the "Select Wi-Fi" screen although I have set the Wi-Fi up
I assume you're using a secure Wifi connection with a password and it seems like that authentication is not working. You could try using an open wifi access point to eliminate the possibility of this authentication issue.
Oct 04, 2014 | Google Nexus 7
Irola dx752
If I am understanding the problem, then you are trying to connect to a network that is password protected (that is what the lock symbol generally means when shown beside a network that has been discovered by your device). It cannot 'authenticate' you until you key in the correct password. However, if that is the case, when you click/touch that network and then touch Connect, it should automatically pop up a box asking for the password. Key in the password (be sure to get upper/lower case correct on any letters), and then touch Connect. If that does not work, or if I misunderstood, then provide additional info and we can try again. Good luck!
Jul 16, 2014 | Tablets & eReaders
Authentication problem
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
Meep will not connet to wifi
Here is the remedy for that error:
We've heard a few reports of Wifi connectivity issues recently, among them 'Authentication error'. If you receive this message, our recommended remedy is to remove all Wifi connection information from your Meep, turn off your Meep, reboot your router, then turn on your Meep and re-add the Wifi information. Follow these steps exactly in this order to resolve this error message:
1. Remove all Wifi network information from the Meep's settings
2. Reboot your router
3. Re-add the Wifi network information to the Meep's settings
4. Reboot the Meep.
Jan 01, 2014 | Oregon Scientific MEEP Kids Tablet
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
My SVP tablet (Model TPC0902) will not connect to my home WIFI. I keep getting this message "authentication problem." How do I fix this? (All my other devices connect just fine)
Tablet worked fine on wireless for first two weeks. Now it's showing a line flickering in the wi-fi icon. I checked Ethernet and reset router button. Nothing.
Aug 11, 2013 | Tablets & eReaders
Why does my tablet keep saying authentication problem when trying to connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Dec 30, 2012 | Archos Arnova 10 4GB 4)
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
May 12, 2012 | Polaroid Tablet Computer PMID701
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
Tablets & eReaders Logo
314 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
