Amazon.cahttps://www.amazon.ca > Exterior-Replacement-CITR...
1.Remove all existing mirror glass from the mirror assembly plastic backing plate. 2.Clean the backing plate with rubbing alcohol and clean the back of the new ...
$70.50 · ‎In stock
They make a replacement mirror glass available that uses double sticky tape. This has worked great for me. The heated function still continued to work!! In my case I replaced a scratched mirror leaving the old mirror in place. If yours is broken included is a link for a procedure to replace a broken mirror.
Confirm the dimensions before purchasing. Some car manufactures have more than one design for different model cars same year..
? 4:06 https://www.youtube.com/watch?v=2LAqSfV-swI
May 23, 2010 - Uploaded by Decibel Car
Want to replace your wing mirrors with aftermarket ones ? Had someone in a shopping mall car park break ...
Remove the screws that hold the mirror and remove it from the door. Attach the new mirror. Reconnect the electrical connector and make sure you test the new mirror before putting the parts back into place. Reverse the entire procedure to reassemble the door trim panel.
You don't replace the motor. Replace the entire mirror. If you want to replace just the motor, you have to remove the mirror first and they break. Either the mirror will break or the tabs that hold the mirror to the motor.
The replacement mirror that you buy at most auto supply stores are not to be used as a replacement for a heated mirror due to fact that the materials used to make the heated mirror are different. You will need to replace it with the same type of mirror from the dealer.
You can buy replacement stick on mirrors at most auto stores... different sizes or you actually cut it to the size you want.... cut out a peice of cardboard to make a template till it fits right on the mirror on the car and use that to get the replacement mirror you need or cut the replacement mirror to size.... peel off the paper on the back... then line up the mirror and push firmly starting in the center of the mirror working outward to make sure the sticky side sticks.
