My trunk want open an its not the battery - Mercedes E-class E320 E350 E500 E550 E63 Exterior Accessory Chrome Abs Molding Trim Kit 2003 2004 2005 2006 2007 2008 2009
Use jumper cables from another car-put the positive jumper cable on the post on the starter where the battery cable connects, then the negative jumper cable to a ground on the frame of your car. Turn on the car you are jumping with and let it run about 10 minutes. It might charge up your battery in the trunk enough to open the trunk.
YOU CAN PLUG IN A BOOSTER BATTERY INTO CIGARETTE LIGHTER IT WILL GIVE CAR BATTERY POWER TO JUMP START. AND YOU WILL HAVE POWER ALSO TO OPEN TRUNK ALSO TO REMOVE BATTERY.
hello,first try to locate your starter motor,there is a big cable connected to solenoid switch up to battery,try to put positive cable first before to another battery,with care,try to open your trunk ,not for starting,remove your battery for changing,ty
I f it is like the XJR, the cig lighter is electrically switched and will not work. Find the hot point and and ground in the passenger side heelboard. The ground is two wires together scewed to the body an the hot point was a bolt attacted to a large wire and covered with a black rubber boot.
