The Compupool CPSC/CPA Series is recommended to run at a salt
concentration of 3500 ppm. If you are not installing a Compupool unit,
check your manufacturer's instructions for their recommended level of
concentration . Use a salt that is at least 99.8% pure NaCl. The
preferred salt is an evaporated, granulated, food quality, NON-iodized
salt. Avoid using salt with anti-caking agents like sodium ferrocyanide,
also known as yellow YPS (prussiate of soda. These cause some
discoloration of fittings and pool surface finishes. DO NOT use calcium
chloride.
Using a salt water test strip, measure the current salt level of your
pool. For the Compupool generators, ideal is 3500 ppm. If the level is
low, determine the number of gallons in your pool and add salt according
to the
Salt Table. For example, if your pool has 15,000 gals of water and your current salt level is 2500, you need to add 125 lbs of salt.
