Cars & Trucks Logo
T
Thomas Posted on Aug 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kia Starts and idles smooth revs great in park seems to run great for a few minutes then stalls and chugs in gear. can get to stay running in park or neutral but wont get any power when in gear.
Code were typical P0303, 302, 300 misfire. changed fuel pump & filter, Coil, wires & plugs, Fuel Injectors, Catalytic Convertors, Crankshaft Position sensor, IAC valve and cleaned MAF, Still no power in gear buts starts and revs great can drive around the block when cold but then stalls again. Need Help Bad!!! Ideas Anyone???
  • Thomas
    Thomas Aug 08, 2015
    cleared the misfire codes but still have same problem under engine load even idling in park with A/C on ???
Claude Kayser
Level 3:
Top Expert:
  • Kia Master 9,098 Answers
  • Posted on Aug 08, 2015
Claude Kayser
Kia Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066282
Points
28436
Trouble shooting a misfire, Code P0300, P0301 ... - YouTube
? 23:39
www.youtube.com/watch?v=G_grIaTgdRI
Oct 26, 2013 - Uploaded by Robert DIY For the new play by play misfire video click here: ... Trouble shooting a misfire, Code P0300, P0301, P0302, P0303, P0304, P0305, P0306, ...
2answers
Car will start but put it in gear engine will die
engine starts with no problem; but, when I put in gear and ...
www.cargurus.com > Questions > Hyundai > Sonata
CarGurusNov 15, 2012 - The engine just fall dead when you step on the gas; it seems to jerk before ... My car does the same thing but i put it in neutral n it starts up. ... I have a 2004 kia optima it jerks when I go into reverse it was driving ... start and run fine butwhen I put it in drive or any other gear it dies! ... 2002 Hyundai Elantra GT.
Engine stalls when tranny put in Drive or Reverse - Kia Forum
www.kia-forums.com/kia-carnival...2002.../43407-engine-stalls-when-tr...
Feb 28, 2008 - 10 posts - ‎3 authors
Give it a little gas before putting in D or R and it will go. .... When I start the van cold and shift the tranny into drive or reverse.....the whole front ... won't run in forward gears - Kia Forum
May 25, 2012
Intriguing problem - engine rough idle & hesitation ...
Aug 31, 2011
2006 Kia Spectra engine stalls and bad idle, cleaning the ...
Aug 30, 2010
2002 Kia Spectra Won't Go Out of Park - Kia Forum
Oct 28, 2008
More results from www.kia-forums.com
2helpful
97 Nissan 200sx 2.0l....car wont stay running when put in gear. When idling sometimes when engine is reved up it stalls, other times while idling I can rev it up and its smooth but once I put it in gear it...
You'll need to change the distributor, as the distributor shaft oil seal has gone bad. Without sufficient spark, you'll have no power. Don't forget a new cap/rotor.
Pathfinder "cuts out" at 2,300 rpm
Replace your MAF, its a little pricey around $280.00 or so but this will clear the code but make sure you have the ECM reprogrammed to perform a "learning" sequence since sometimes the code will not clear even though the vehicle will run like new. This reprogramming will most likely have to be a dealer performed procedure.
1helpful
When I start the car it stays at 2000rpm for a few moments then drops down. I'll drive for a few minutes then put it in park and it revs up and down.
idle air control valve is bad replace it. at start up choke control runs till warm up while driving throttle opening controls engine at idle ,the idle air control valve.
Rainy weather, car sputters or will not run at all
Check for condensation in the distributor cap.
3helpful
04 Jeep starts but stalls when put into gear.
make sure your idle air control motor is working, if you give and hold gas pedal a little will it stay running in drive.
Engine stalls when warm, idles faulty
I would suggest a computerised diagnostic to find the fault else it may take forever..
Taurus 2003 idling problems
mcdevito75 here, Sounds like the idle speed motor, Ford is known for these idle speed motors going bad, in the later stages the car races like crazy. have your repair shop check this idle speed motor and change it.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
