Alarm keepsgoing off? - Audio Players & Recorders
  • 3,866 Answers
Should you post a model number i could tell you how to fix that alarm. Sometimes when the power goes out or if there is a battery backup the alarm set previously was not reset thus goes of at that set time.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 07, 2015
SOURCE:
A f&p top load washer wa1068gi keepsgoing out of balance
check cabinet is level , check that the bowl is level
if the bowl is not level but the cabinet is check for failure of the plastic insulators that support the bowl
Mar 26, 2017 | Washing Machines
It just keepsgoing through setup
Microsoft stopped doing any security updates for Windows XP about two years ago. You should not use this on any machines anymore, it will quickly get hacked when you go online. Hackers are using information from updates that microsoft is still doing for newer versions of windows to guide them in finding weaknesses in windows XP. Many website will even pop up warnings about using Windows XP when you visit.
https://www.microsoft.com/en-us/WindowsForBusiness/end-of-xp-support
If you need free software to work on your computer try Ubuntu Linux. It even includes an office suite like Microsoft Office!
Get it free here:
http://www.ubuntu.com/download/desktop
Sep 19, 2015 | Microsoft Windows XP Professional With...
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
Enging coolant keepsgoing down the enigein
Take your Gigabyte motherboard to a qualified computer dealer,
and have it inspected for leaks, and have the technician connect their diagnostic computer to your hardware, and run the diagnostics.
Dec 26, 2009 | Gigabyte COOLANT LIQUID IN BOTTLE (BLUE)
I cant get my second alarm to be set on the alarm sound how do i get my second alarm off of radio of cd mode
products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
copy and paste the above link in your internet address bar under a new tab. It is your entire manual.
Hold down ALARM SET and press ALARM MODE. The Alarm 2 indicator flashes. You now have 10 seconds to begin setting Alarm 2. Note: The Alarm 2 indicator must be flashing while setting Alarm 2 wake up time or sound. To set Alarm 2 wake up time, hold down ALARM SET and press either TUNING button
For manual copy and paste this link in your internet address bar under a new tab:
Oct 14, 2009 | Bose Wave Radio
Kenmore refigerator keepsgoing into defrost mode
Hi, If you changed relay, overload, & capacitor on the compressor and it still clicks on and off, the compressor has gone bad and will need replaced. Is this unit under five years old?
Vic
May 28, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Nokia 6020 keepsgoing to headset function
Dial *#7370# now it will ask restore original device settings,yes,it will ask for password its-12345, your phone will restart, all the data on our phone memory will be deleted,and it will be like when you first bought it,PLEASE DO IT ON YOUR OwN RISK,OR GO YOUR NEAREST NOKIA SERVICE CENTRE. ALL the best
May 27, 2008 | Nokia 6020 Cellular Phone
70 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
