j
james nichols Posted on Aug 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change toner
How do I change toner
Mister Danger
Level 3:
  • Master 5,631 Answers
  • Posted on Aug 07, 2015
Mister Danger
Master
Level 3:
Answers
5631
Questions
0
Helped
1197674
Points
47629
Normally the procedure is indicated in the manual. Check the manual of your unspecified printer or copier.
Procedure is different on each device. Just for your illustration, enjoy some videos about how to replace toners on copier:
How to Replace Toner in your Ricoh Copier
SHARP COPIER How to replace toner cartridge
How to Replace Toner in Canon ImageRUNNER Copier
Toshiba copier 2006 toner change
If 'change toner' persist after toner is loaded.
Don't use fake or refilled toner cartridges. There are chips in them that know and tell the mystery machine that you have.
My ricoh mpc 2500 keep saying add black toner whereas there is toner in the toner bottle
If asking for black toner did you change rt toner pump should been one behind the black dev unit. Sometimes when you change it might have to open and close front door. A couple of times make sure you leave it open long enough that it think you change bottle
Canon ir 1020
I have canon printer ir 1020, when I need to change a toner the printer detect if the toner that i have putted is empty, but the toner is the new one. what is the problems/ and how to fix it?
1helpful
HL215ON changing toner How do I change the toner?
Its not very hard to replace toner cartridge on your brother laser printer. please click the link below and follow the instructions with diagram, to replace toner cartridge:---- http://technoanswers.blogspot.com/2011/06/how-to-replace-toner-cartridge-on.html ----------- this should help.thanks.helpmech,
1helpful
Have a c1900 but no disk for utility management to change toner cartridges, how do I get around this and change toner cartridges? Drivers are installed and printer in operation hence need to change...
You go through the menus :
Press Right arrow once,
Then down arrow 5 times (to Reset Menu)
The Down arrow 5 times to Change toner C (Cyan)
Then down arrow again to Change toner M (Magenta)
Then down arrow again to Change toner Y (Yellow)
Then down arrow again to Change toner k (Black)
Select your colour to change and press the right arrow. The engine durns, open the door and remove the cartridge
I would like to change the toner how to change it machine is toshiba e studio 45
You have to purchase genuine toner catridge from toshiba dealer . after purchasing the toner
1) Open the front toor
2) Toner catridge is there on above of the drum unit, there will be lock for toner catridge cover on the machine, it needs to be opened
3)Rotate the toner catridge in clock wise and pull the catridge ,it will come out
4)Insert the new catridge and rotate clockwise at a time it will get enhance with toner motor
5) close the toner cat cover, front door, TURN ON the machine it will get rotate for few seconds (adding toner) then it will becomes ready
Canon Ir2018 always indicating ''no toner, change toner''
Because you need to clean and shake the toner unit. When you say " ive been fixing" does it mean that you now what you are doing or?
If yes dismantle the toner unit and vacume it, it may be that toner stucked on "antena" for toner recognitions.
If not - call service
Pls. rate
3helpful
2answers
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
k24674
ADMIN Andrew
ADMIN Andrew
