I forgot the password to my dell latitude xt lasptop...help
SOURCE: dell latitude d620 bios password removal
To remove a BIOS password will require the assistance of Dell Tech Support. 800-624-9896 You will have to be able to prove you are an authorized user and if out of warranty a Fee may be involved.
SOURCE: dell latitude d630 forgot bios password
Go to Dell support and download the latest BIOS revision. When you flash the bios it should wipe out the password. The second option is not as appealing.... open up the laptop and remove the CMOS battery for 30 seconds. This is much easier on a desktop, but a proven solution if there is no other way.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_b1cdba8db959d216
SOURCE: reset bios password dell latitude d520
Each manufacturer uses a backdoor password for this exact reason. for Dell - it is Dell. It may work, but if not try to remove the CMOS battery for 30 seconds to 1 minute. Turn
the computer upside-down and to help prevent damage to the system board,
remove the main battery before working inside the computer. Remove the main battery: Slide the battery-bay latch release on the bottom of the
computer and then remove the battery from the battery
bay. Remove the CMOS battery- loosen the captive screw on the RAM cover, and
then remove the cover. Use a plastic scribe to slide into the guide on the side
of the coin-cell battery compartment, and lift the battery out.
When you replace the battery, insert it at a
30-degree angle under the clip with the positive (identified by a plus [+]
symbol) side up, and then push it into place.
You BIOS password should now be reset.
SOURCE: Forgot Admin Password for Dell Latitude D620
when i got my Dell Windows 7 admin password, I follow video tutorial to reset password easily:
http://www.youtube.com/watch?v=IDIyKd8dNrQ
i want to reset my dell latitude C400 because i forgot the hard disk password how can i open it without typing the password
