It sounds like the the ones with red and black stripes are possitive and negatives for your speakers then the others are positives also you would need a 12v test light to see witch wires have power to them and go from there
Hi.
On the drums for each colour there is a purple/blue/green slider for cleaning the corona wire. If there is a stripe of colour anywhere on the page going from top to bottom check these sliders. They need to be where the arrow on the slider meets the arrow on the drum casing.
As for low toner on the Yellow and Magent - Replace the cartridges.
Hello, if you have blue stripes moust likely some of the Magenta or Yellow nozzels are clogged. I recomand to execute head cleaning and deap head cleaning BUT with OEM cartridges. If that dosent help take the print head out of the printer and let it soak in distiled wather at 30-35 degrees Celsius. If that still dosent work you will need a new print head.
In Hapkido, there are 11 levels, each represented by a belt color. The order is as follows (from low to high): white belt, white belt with yellow stripe, yellow belt, yellow belt with green stripe, green belt, green belt with blue stripe, blue belt, blue belt with red stripe, red belt, red belt with black stripe, and black belt.
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the
steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug) Rear Right speaker -: Blue w/White stripe Rear Left speaker -: Brown w/Yellow stripe Front Right +: Purple Front Left +: Dark Green Rear Right speaker +: Blue w/Orange Stripe Rear Left speaker +: Brown w/Blue Stripe Power Antenna/Amp: White (Gray Plug) +12v battery wire: Pink or Pink w/White Stripe +12v Ignition wire: Red w/ White Stripe Front Right speaker -: Blue w/ Red Stripe Front Left speaker -: Brown w/ Red Stripe
You are printing a pictures that was made in RGB mode (red green blue). You need to convert this picture to CMYK which is how printers print.
See how here: http://www.printingforless.com/rgb-cmyk.html
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
