Since installing eprint, the printer no longer recognizes the computer and refuses to print online.
Usually for HP printers not being recognized because they loose their IP address on the network or the computer can't see it.
What you can do is completley uninstall the HP software for the Officejet 8600, then go to HP.com lookup the officejet 8600 under Support > Download Drivers. download the latest full installation then run the install. When it ask you how to install it do the custom install and then only select the things you want to install.
When it ask you to do the eprint set up you can skip that part. also once install try running the HP updates for find any Network fixes or and Firmware updates.
HP Officejet Pro 8600 All in One Printer N911a Software and Drivers
SOURCE: hp2400 will scan, copy, fax, but not print from computer any more
sir,
u need to install the drivers and software for ur printer. if u have already installed try to uninstall and install them...
click this link for drivers
also this
thanks
good luck
SOURCE: Printer won't print without a CD.
Just about all manufacturer's havce drivers online that you can download and install easily. If you have an HP Photosmart C5180 and a little patience, I can find the driver link for you... or you can go to the HP site and browse for it yourself.
SOURCE: won't recognize new ink cartridges and computer
remove cartridge and clean it using tissue paper and put it back again
